hey guys i have a sierra electric dizzy to go in my f10a it has a resistor on the coil, do i need to remove it and install or is there any other tricks?
Not sure, mine is a Maruti Dizzy which has a black wire with white stripe that goes to positive side of the coil and a brown wire which goes to the negative. Then a black wire at the base of the dizzy housing which I just ran to the body.
The wiring diagram on Suzuki Info says it is black wire with white trace that goes to positive side of the coil, brown with white trace to negative of the coil.
Users browsing this forum: No registered users and 85 guests
