It is currently Wed Oct 14, 2026 5:53 pm
Post Posted: Sun Oct 07, 2012 11:36 am
does anyone know what this arch moulding is called i cannot find it anywhere :/
Post Posted: Sun Oct 07, 2012 11:47 am
I don't know how you would go sourcing that product by itself, but many after market flares come with this material:
http://www.7ent.com/products/seating-st ... l0059.html
which you may be able to use to do what you want.
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Oct 07, 2012 12:47 pm
Clark rubber have a similar thing Blakey but its in black
Post Posted: Sun Oct 07, 2012 6:31 pm
+1 for Clark rubber. That's where I got some from for my zook
Post Posted: Sun Oct 07, 2012 7:39 pm
Should be available (at a cost) from Suzuki.....
Part numbers...
Moulding side RH (GREY) 77130-70A00-5WA
Moulding side LH (GREY) 77140-70A00-5WA
Post Posted: Mon Oct 08, 2012 1:40 am
Clark rubber one is $$$$. Will be cheaper from any rubber supplier, check eBay too.
Post Posted: Mon Oct 08, 2012 3:09 pm
the ones from suzuki are not long enough. i need them to cover my different arches plus they are most likely super expensive and id really rather it in white as i want them to be white and paint on rubber wont last to long.
and i checked out Clark rubber and as stated they only have it in black plus its almost $6 a meter more expensive then copper :O
checked out ebay and cant find anything like it not even in black.
Post Posted: Mon Oct 08, 2012 4:20 pm
I think you're going to be out of luck. 80 series cruisers used a similar moulding. You would try to get some from a wrecker, but IIRC it's pretty brittle and is unlikely to accept the new bends you'll be asking it to do.
Have you considered white draft excluding material? I assume you're trying to prevent grit getting between the flare and body and wrecking the paint/causing rust?
Post Posted: Mon Oct 08, 2012 5:17 pm
yer iv had a look into a few things really anything that's a similar or t shaped will work but the only t shaped mouldings if found are way to large.
but yes its for protection against the sharpish plastic and grit damaging the paint and causing rust
Post Posted: Mon Oct 08, 2012 5:23 pm
try fitch the rubber man
Post Posted: Tue Oct 09, 2012 11:58 am
I need it in white tho and i dont think rubber comes in white, so it might be a plastic job
Vehicle: chick magnet coily
Post Posted: Sat Oct 13, 2012 1:30 pm
is this stuff for the flares?
if so i have it for all four flares if you want it
Post Posted: Sat Oct 13, 2012 1:57 pm
Blakey has defender flares on his Jimny so needs lots of it without joins.
Post Posted: Sat Oct 13, 2012 3:20 pm
ohhh ok
Post Posted: Sun Oct 14, 2012 1:15 pm
DEFENDER flares....
What strip do LandRover use?
Post Posted: Sun Oct 14, 2012 2:46 pm
They're aftermarket defender flares.
Stock defenders don't have a strip IIRC.
Post Posted: Mon Oct 15, 2012 4:40 pm
yep i might just have to use some of that foam double sided tape just to stop stuff getting between. and not worry about having that type of moulding. it would just look nicer with it.
Users browsing this forum: No registered users and 62 guests
