| Author |
Message |
Blakey
Joined: Sun Mar 04, 2012 6:11 pm Posts: 464 Location: Brisbane, Petire
 Posted: Sun Oct 07, 2012 11:36 am |
does anyone know what this arch moulding is called i cannot find it anywhere :/
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Sun Oct 07, 2012 11:47 am |
jimny_timmy
Vehicle: Suzuki Jimny 2010
 Posted: Sun Oct 07, 2012 12:47 pm |
Clark rubber have a similar thing Blakey but its in black
mrw82
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
 Posted: Sun Oct 07, 2012 6:31 pm |
+1 for Clark rubber. That's where I got some from for my zook
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sun Oct 07, 2012 7:39 pm |
Should be available (at a cost) from Suzuki..... Part numbers...
Moulding side RH (GREY) 77130-70A00-5WA Moulding side LH (GREY) 77140-70A00-5WA
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5944 Location: Northcliffe, W.A.
 Posted: Mon Oct 08, 2012 1:40 am |
jimny_timmy wrote: Clark rubber have a similar thing Blakey but its in black Clark rubber one is $$$$. Will be cheaper from any rubber supplier, check eBay too.
Blakey
 Posted: Mon Oct 08, 2012 3:09 pm |
the ones from suzuki are not long enough. i need them to cover my different arches plus they are most likely super expensive and id really rather it in white as i want them to be white and paint on rubber wont last to long.
and i checked out Clark rubber and as stated they only have it in black plus its almost $6 a meter more expensive then copper :O
checked out ebay and cant find anything like it not even in black.
Gwagensteve
 Posted: Mon Oct 08, 2012 4:20 pm |
I think you're going to be out of luck. 80 series cruisers used a similar moulding. You would try to get some from a wrecker, but IIRC it's pretty brittle and is unlikely to accept the new bends you'll be asking it to do.
Have you considered white draft excluding material? I assume you're trying to prevent grit getting between the flare and body and wrecking the paint/causing rust?
Blakey
 Posted: Mon Oct 08, 2012 5:17 pm |
yer iv had a look into a few things really anything that's a similar or t shaped will work but the only t shaped mouldings if found are way to large.
but yes its for protection against the sharpish plastic and grit damaging the paint and causing rust
atari4x4
 Posted: Mon Oct 08, 2012 5:23 pm |
try fitch the rubber man
Blakey
 Posted: Tue Oct 09, 2012 11:58 am |
I need it in white tho and i dont think rubber comes in white, so it might be a plastic job
fully sick coily
Joined: Tue Feb 14, 2012 7:47 pm Posts: 474 Location: brisbane
Vehicle: chick magnet coily
 Posted: Sat Oct 13, 2012 1:30 pm |
is this stuff for the flares?
if so i have it for all four flares if you want it
Gwagensteve
 Posted: Sat Oct 13, 2012 1:57 pm |
Blakey has defender flares on his Jimny so needs lots of it without joins.
fully sick coily
 Posted: Sat Oct 13, 2012 3:20 pm |
want33s
 Posted: Sun Oct 14, 2012 1:15 pm |
Gwagensteve wrote: Blakey has defender flares on his Jimny so needs lots of it without joins.
Steve. DEFENDER flares.... What strip do LandRover use?
Gwagensteve
 Posted: Sun Oct 14, 2012 2:46 pm |
They're aftermarket defender flares.
Stock defenders don't have a strip IIRC.
Blakey
 Posted: Mon Oct 15, 2012 4:40 pm |
yep i might just have to use some of that foam double sided tape just to stop stuff getting between. and not worry about having that type of moulding. it would just look nicer with it.
