It is currently Tue Aug 11, 2026 10:18 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2  Next
Vehicle: 92 WT Sierra
Post Posted: Mon Mar 03, 2014 12:42 pm
Hi all,
I have searched around (as best as I can) and can't find anyone in Australia who is making a kit to fit hilux cv's to a Vitara. The only ones I have been able to find are in the us and from a few years ago. Does anyone know of such a kit or has made one?
Thanks and sorry if I have missed something in my searching
Post Posted: Mon Mar 03, 2014 12:44 pm
not as yet but im hoping to have them in production by mid year.
Post Posted: Mon Mar 03, 2014 8:41 pm
Nice, any idea on a rough price range. Trying to work out a way of going bigger tyres reliably on the vit or go to a sierra
Vehicle: SWB Vitara
Post Posted: Tue Mar 04, 2014 12:13 am
Something like this?
So you can do this?
Ask BenT (the guy who does the 1600 adapter kits and the Vitara rear disc kits). Not sure if it is awaiting final testing (mostly because the prototype is sitting in the back of my Vitara waiting to be installed) or whether he is ready to go with supplying them.
PM him for availability and pricing.
Post Posted: Tue Mar 04, 2014 8:15 am
seems like an overly complicated way of doing it to me.
Post Posted: Tue Mar 04, 2014 8:32 am
Thanks Pico will do. Tanshi the ones I have seen just rely on the brass bush to do the sealing on the back of the hub. As far as I know the internals of aisin hubs are interchangeable between most makes, so could possibly use the stock zook hub with toyota internals if the kit allowed.
Post Posted: Tue Mar 04, 2014 8:46 am
it does need the spacer because the stub axle on the cv is longer, but its notmally just a disk with holes in it.
the shaped machining seems like over kill to me
Post Posted: Tue Mar 11, 2014 12:51 am
True, but it's kinda purdy...
Vehicle: SWB Vitara
Post Posted: Sun Mar 16, 2014 12:37 am
That it is. I liked it.
Post Posted: Sun Mar 16, 2014 11:35 am
Where's that kit from?
Vehicle: SWB Vitara
Post Posted: Sun Mar 16, 2014 6:18 pm
From this guy, BenT
http://auszookers.com/forum/viewtopic.php?f=15&t=15009
I have his disc brake set and was very impressed with it, so approached him about putting together a Toyota CV kit (after I couldn't get hold of Stan /37Kicker). This was the result. I will get it installed in a few weeks time, then test it out over Easter. But to be honest I am not expecting any issues - the concept of it is pretty straightforward.
Post Posted: Wed Mar 19, 2014 1:11 pm
I've had Ben's disc kit on the back of both my Vits. Didn't realise he was doing these...
Vehicle: SWB Vitara
Post Posted: Sun May 04, 2014 10:53 pm
Installed and in use.
Post Posted: Sat Aug 16, 2014 5:19 pm
Bump, any progress?
Post Posted: Sun Aug 17, 2014 8:38 am
SAS..
Vehicle: 85 SJ413
Post Posted: Thu Aug 21, 2014 7:38 pm
VitNick wrote:
Bump, any progress?
Yes! I've just made a small batch of kits and have them ready to go now. See here for more details:
http://www.auszookers.com/forum/viewtopic.php?p=840771#p840771
Ben
Post Posted: Thu Aug 21, 2014 7:42 pm
yess!!!
what's the go with running it on a SV vitara or haven't you had a chance?
Vehicle: 04 Grand Vitara, 2.5L, V6
Post Posted: Thu Aug 21, 2014 7:50 pm
Or on a gv ;)
Vehicle: 85 SJ413
Post Posted: Thu Aug 21, 2014 7:51 pm
I've only have the one kit running on Pico42's Vitara so far, but when making the kit I measured some SV cv's and they were quite a bit longer than the SE ones, so there's a chance it might fit in without the Hagen mod. I can't think of anything else that would stop it fitting an SV.
Ben
Post Posted: Thu Aug 21, 2014 8:20 pm
Sv and gv with a stubby run the se cv on the ds and gv/sv cv so should fit on ds but ps may need a further spacer...
Vehicle: 85 SJ413
Post Posted: Thu Aug 21, 2014 8:34 pm
Right, I see... although the Toyota CV has quite a bit more plunge travel, so may be able to take up the extra distance without another / a thicker spacer.
Are the SV and GV CV's exactly the same?
Post Posted: Thu Aug 21, 2014 8:59 pm
They are interchangeable on the ps of the gv and sv the ds need an se cv with the stubby as the sv is too long. Sorry to any one who is confused by the short hand. To run the se cv on both sides it needs around a 30mm spacer on the ps. I don't thi k the luv cv has that much room at rest plus travel.
Vehicle: 85 SJ413
Post Posted: Fri Aug 22, 2014 9:04 am
The Toyota CV with adaptors fitted is about 15mm shorter than the SV shaft, but has 20mm more travel, so its going to be close to fitting I think.
Sounds like I have a tester keen to try the kit in a GV now, so watch this space.
Post Posted: Fri Aug 22, 2014 1:01 pm
I like the sound of that! I already have cv spacers so if it needs it to have a bit more travel and fits that's fine with me.
Post Posted: Sun Sep 21, 2014 8:43 pm
Shoot one to Sydney and I'll test fit it in an SV for ya.
Waiting on a big invoice to be paid and I might be able to afford it.
One day I might be able to drive test it too... :(
Vehicle: 2002 Suzuki Grand Vitara wide
Post Posted: Mon Sep 22, 2014 9:08 am
So, what is the weak point of the Vitara se, Sv/Gv CV joint/ shaft assemblies?
Is it the Cv's themselves, cages breaking?
Or stub axles, shaft breakages?
In what way are Hilux shafts better? Heavier duty, I guess. But thicker shafts? Bigger cv's?
Noob questions.
Post Posted: Mon Sep 22, 2014 10:47 am
Vit Cvs don't always break in the same way they break cages, housing, strip splines. Pretty much everything. Lux cvs are bigger in pretty much everyway.
Vehicle: 85 SJ413
Post Posted: Mon Sep 22, 2014 10:55 am
I have a kit being test fitted to a GV at the moment, and as far as I know the GV and SV cv shafts are the same, so will know shortly how it fits.
Vehicle: suzuki Grand Vitara
Post Posted: Tue Sep 23, 2014 7:30 pm
Which model GV are you treating on? Do they all have the same set up?
Testing*
Users browsing this forum: No registered users and 59 guests
