| Author |
Message |
VitNick
Vehicle: 92 WT Sierra
 Posted: Mon Mar 03, 2014 12:42 pm |
Hi all,
I have searched around (as best as I can) and can't find anyone in Australia who is making a kit to fit hilux cv's to a Vitara. The only ones I have been able to find are in the us and from a few years ago. Does anyone know of such a kit or has made one? Thanks and sorry if I have missed something in my searching
tanshi
 Posted: Mon Mar 03, 2014 12:44 pm |
not as yet but im hoping to have them in production by mid year.
VitNick
 Posted: Mon Mar 03, 2014 8:41 pm |
Nice, any idea on a rough price range. Trying to work out a way of going bigger tyres reliably on the vit or go to a sierra
Pico42
Joined: Sun Nov 20, 2011 8:05 am Posts: 82 Location: Brisbane AU, Queenstown NZ
Vehicle: SWB Vitara
 Posted: Tue Mar 04, 2014 12:13 am |
Something like this?  So you can do this?  Ask BenT (the guy who does the 1600 adapter kits and the Vitara rear disc kits). Not sure if it is awaiting final testing ( mostly because the prototype is sitting in the back of my Vitara waiting to be installed) or whether he is ready to go with supplying them. PM him for availability and pricing.
tanshi
 Posted: Tue Mar 04, 2014 8:15 am |
seems like an overly complicated way of doing it to me.
VitNick
 Posted: Tue Mar 04, 2014 8:32 am |
Thanks Pico will do. Tanshi the ones I have seen just rely on the brass bush to do the sealing on the back of the hub. As far as I know the internals of aisin hubs are interchangeable between most makes, so could possibly use the stock zook hub with toyota internals if the kit allowed.
tanshi
 Posted: Tue Mar 04, 2014 8:46 am |
it does need the spacer because the stub axle on the cv is longer, but its notmally just a disk with holes in it.
the shaped machining seems like over kill to me
DarkHorse
 Posted: Tue Mar 11, 2014 12:51 am |
True, but it's kinda purdy...
Pico42
Vehicle: SWB Vitara
 Posted: Sun Mar 16, 2014 12:37 am |
DarkHorse wrote: True, but it's kinda purdy... That it is. I liked it.
DarkHorse
 Posted: Sun Mar 16, 2014 11:35 am |
Pico42
Vehicle: SWB Vitara
 Posted: Sun Mar 16, 2014 6:18 pm |
DarkHorse wrote: Where's that kit from? From this guy, BenT http://auszookers.com/forum/viewtopic.php?f=15&t=15009I have his disc brake set and was very impressed with it, so approached him about putting together a Toyota CV kit (after I couldn't get hold of Stan /37Kicker). This was the result. I will get it installed in a few weeks time, then test it out over Easter. But to be honest I am not expecting any issues - the concept of it is pretty straightforward.
DarkHorse
 Posted: Wed Mar 19, 2014 1:11 pm |
I've had Ben's disc kit on the back of both my Vits. Didn't realise he was doing these...
Pico42
Vehicle: SWB Vitara
 Posted: Sun May 04, 2014 10:53 pm |
Installed and in use.
VitNick
 Posted: Sat Aug 16, 2014 5:19 pm |
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sun Aug 17, 2014 8:38 am |
SAS..
_________________ mlm
BenT
Joined: Sun Nov 16, 2008 10:30 pm Posts: 208 Location: Nelson, NZ
Vehicle: 85 SJ413
 Posted: Thu Aug 21, 2014 7:38 pm |
atari4x4
 Posted: Thu Aug 21, 2014 7:42 pm |
 ! what's the go with running it on a SV vitara or haven't you had a chance?
Sco-tie
Joined: Fri Apr 06, 2012 5:02 pm Posts: 928 Location: Adelaide hills!
 Posted: Thu Aug 21, 2014 7:50 pm |
Or on a gv
BenT
Vehicle: 85 SJ413
 Posted: Thu Aug 21, 2014 7:51 pm |
atari4x4 wrote: what's the go with running it on a SV vitara or haven't you had a chance? I've only have the one kit running on Pico42's Vitara so far, but when making the kit I measured some SV cv's and they were quite a bit longer than the SE ones, so there's a chance it might fit in without the Hagen mod. I can't think of anything else that would stop it fitting an SV. Ben
Sco-tie
 Posted: Thu Aug 21, 2014 8:20 pm |
Sv and gv with a stubby run the se cv on the ds and gv/sv cv so should fit on ds but ps may need a further spacer...
BenT
Vehicle: 85 SJ413
 Posted: Thu Aug 21, 2014 8:34 pm |
Sco-tie wrote: Sv and gv with a stubby run the se cv on the ds and gv/sv cv so should fit on ds but ps may need a further spacer... Right, I see... although the Toyota CV has quite a bit more plunge travel, so may be able to take up the extra distance without another / a thicker spacer. Are the SV and GV CV's exactly the same?
Sco-tie
 Posted: Thu Aug 21, 2014 8:59 pm |
They are interchangeable on the ps of the gv and sv the ds need an se cv with the stubby as the sv is too long. Sorry to any one who is confused by the short hand. To run the se cv on both sides it needs around a 30mm spacer on the ps. I don't thi k the luv cv has that much room at rest plus travel.
BenT
Vehicle: 85 SJ413
 Posted: Fri Aug 22, 2014 9:04 am |
The Toyota CV with adaptors fitted is about 15mm shorter than the SV shaft, but has 20mm more travel, so its going to be close to fitting I think.
Sounds like I have a tester keen to try the kit in a GV now, so watch this space.
Sco-tie
 Posted: Fri Aug 22, 2014 1:01 pm |
I like the sound of that! I already have cv spacers so if it needs it to have a bit more travel and fits that's fine with me.
DarkHorse
 Posted: Sun Sep 21, 2014 8:43 pm |
Shoot one to Sydney and I'll test fit it in an SV for ya. Waiting on a big invoice to be paid and I might be able to afford it. One day I might be able to drive test it too...
Bosco15
Joined: Sun Aug 10, 2014 12:14 pm Posts: 56 Location: Newcastle Nsw
Vehicle: 2002 Suzuki Grand Vitara wide
 Posted: Mon Sep 22, 2014 9:08 am |
So, what is the weak point of the Vitara se, Sv/Gv CV joint/ shaft assemblies? Is it the Cv's themselves, cages breaking? Or stub axles, shaft breakages? In what way are Hilux shafts better? Heavier duty, I guess. But thicker shafts? Bigger cv's? Noob questions.
Sco-tie
 Posted: Mon Sep 22, 2014 10:47 am |
Vit Cvs don't always break in the same way they break cages, housing, strip splines. Pretty much everything. Lux cvs are bigger in pretty much everyway.
BenT
Vehicle: 85 SJ413
 Posted: Mon Sep 22, 2014 10:55 am |
DarkHorse wrote: Shoot one to Sydney and I'll test fit it in an SV for ya. I have a kit being test fitted to a GV at the moment, and as far as I know the GV and SV cv shafts are the same, so will know shortly how it fits.
Ricey
Vehicle: suzuki Grand Vitara
 Posted: Tue Sep 23, 2014 7:30 pm |
Which model GV are you treating on? Do they all have the same set up?
Ricey
