| Author |
Message |
Tiop
Vehicle: Sierra '90
 Posted: Sat Apr 12, 2014 7:56 am |
Hi
1st post had my sierra for a week but i don't know if its stock suspension or not, rear shocks are stuffed they have a sticker on them selby suspension and the front springs had a TJM sticker.
any one know what stock ride height is center of wheel to guard is about 460mm front and 480mm rear (parked on slight down hill)
Thanks
ZukinLao
Vehicle: 98 Coily
 Posted: Sun Apr 13, 2014 2:16 pm |
Don't have the stock height right now but looks pretty close from the pic you posted if those are 205's. Will measure for you when I pick up my wife's Coily from the shop in a few days...
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Sun Apr 13, 2014 2:47 pm |
^^as above if those are standard tyres than that looks stock.
Tiop
Vehicle: Sierra '90
 Posted: Mon Apr 14, 2014 7:45 am |
well if thats stock im glad  might ad a lift yet
Rhinoman
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
 Posted: Fri Apr 18, 2014 5:31 am |
The front springs are normally flat so if they have a noticeable arch to them then its lifted.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Fri Apr 18, 2014 6:37 am |
Rhinoman wrote: The front springs are normally flat so if they have a noticeable arch to them then its lifted. It's a coily
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Rhinoman
 Posted: Fri Apr 18, 2014 6:42 am |
shep wrote: Rhinoman wrote: The front springs are normally flat so if they have a noticeable arch to them then its lifted. It's a coily  In that case if the springs are flat then its a bit broken  . If I tilt my screen a bit I can see the trailing arms
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Thu Apr 24, 2014 9:19 pm |
id say thats a 40mm lift kit. given buy the fact it has aftermaket springs/shocks AND the rear arms are dead flat. just going buy experience this was my old coily stock with no lift at all
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
jonno_racing
 Posted: Thu Apr 24, 2014 9:40 pm |
coily96
Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
 Posted: Fri Apr 25, 2014 6:36 am |
I was going to say 40mm too. Give away is the angle of the radius arms.
Stock then 40mm
Tiop
Vehicle: Sierra '90
 Posted: Mon Jun 16, 2014 1:33 am |
cool thanks for the help, ill assume it possible it has some lift  took the front sway bar off much better also, might buy some tires now, thinking 225/75/15
Weiry
Vehicle: '83 SJ40T G13BA 5-Speed
 Posted: Thu Aug 27, 2020 9:04 pm |
jonno_racing wrote: and here you go with 40mm coils just to reinforce my point  Ancient thread I know, but i have to know what tyres are they? Can't quite read what's on the side. Makes that thing look mint!
Gwagensteve
 Posted: Thu Aug 27, 2020 9:16 pm |
Pretty sure they’re now long gone mongrel remoulds (centipede/silverstone copy)
rexhunta
Joined: Sun Jan 26, 2014 9:03 am Posts: 212 Location: Leschenault, WA.
Vehicle: 2020 Vitara Turbo
 Posted: Sat Aug 29, 2020 9:35 am |
Gwagensteve wrote: Pretty sure they’re now long gone mongrel remoulds (centipede/silverstone copy) That's what they are. Every now and then a set come up on gumtree, usually dry rotted. Even Silverstones are getting hard to find over here.
