It is currently Sat Sep 19, 2026 9:42 pm
Vehicle: Sierra '90
Post Posted: Sat Apr 12, 2014 7:56 am
Hi
1st post had my sierra for a week but i don't know if its stock suspension or not, rear shocks are stuffed they have a sticker on them selby suspension and the front springs had a TJM sticker.
any one know what stock ride height is center of wheel to guard is about 460mm front and 480mm rear (parked on slight down hill)
Thanks
Vehicle: 98 Coily
Post Posted: Sun Apr 13, 2014 2:16 pm
Don't have the stock height right now but looks pretty close from the pic you posted if those are 205's. Will measure for you when I pick up my wife's Coily from the shop in a few days...
Vehicle: SJ80, SE416
Post Posted: Sun Apr 13, 2014 2:47 pm
^^as above if those are standard tyres than that looks stock.
Vehicle: Sierra '90
Post Posted: Mon Apr 14, 2014 7:45 am
well if thats stock im glad :) might ad a lift yet
Post Posted: Fri Apr 18, 2014 5:31 am
The front springs are normally flat so if they have a noticeable arch to them then its lifted.
Post Posted: Fri Apr 18, 2014 6:37 am
It's a coily :wink:
Post Posted: Fri Apr 18, 2014 6:42 am
It's a coily :wink:
In that case if the springs are flat then its a bit broken :D :D. If I tilt my screen a bit I can see the trailing arms :oops:
Post Posted: Thu Apr 24, 2014 9:19 pm
id say thats a 40mm lift kit.
given buy the fact it has aftermaket springs/shocks AND the rear arms are dead flat.
just going buy experience
this was my old coily stock with no lift at all
Post Posted: Thu Apr 24, 2014 9:40 pm
and here you go with 40mm coils just to reinforce my point
Vehicle: Coil Sierra
Post Posted: Fri Apr 25, 2014 6:36 am
I was going to say 40mm too. Give away is the angle of the radius arms.
Stock then 40mm
Vehicle: Sierra '90
Post Posted: Mon Jun 16, 2014 1:33 am
cool thanks for the help, ill assume it possible it has some lift :) took the front sway bar off much better also, might buy some tires now, thinking 225/75/15
Vehicle: '83 SJ40T G13BA 5-Speed
Post Posted: Thu Aug 27, 2020 9:04 pm
Ancient thread I know, but i have to know what tyres are they? Can't quite read what's on the side. Makes that thing look mint!
Post Posted: Thu Aug 27, 2020 9:16 pm
Pretty sure they’re now long gone mongrel remoulds (centipede/silverstone copy)
Vehicle: 2020 Vitara Turbo
Post Posted: Sat Aug 29, 2020 9:35 am
That's what they are. Every now and then a set come up on gumtree, usually dry rotted. Even Silverstones are getting hard to find over here.
Users browsing this forum: No registered users and 57 guests
