Vehicle: 89 suzuki sierra
Posted: Tue Jan 16, 2018 6:12 pm
Hello all I am putting a g16a....yes i know its not the ideal motor, the question I have is will i need to do the sump conversion, i have 30mm body lift and 25mm longer shackles and have 30mm extended bumpstops.. I know I could trial fit it when i take the g13 out but i am trying to get the motor as close to bolt in as i can
Joined: Sat Aug 27, 2016 7:52 pm Posts: 37 Location: South Australia
Vehicle: LWB tray top G13B
Posted: Thu Jul 05, 2018 9:25 pm
Hey mate, I've done heaps of searching but can't really find any answers. G16A into where a G13A was, basically just get the adapter kit, modify sump (if needed) and you're good to go? is that all? Cheers
It will depend if your going to a 8 valve or 16 valve. If your going 8 valve and running your 1300 carb, then it’s pretty straight forward. But if your going for the 16 valve or injection on the 8 valve then there’s more wiring to deal with
Users browsing this forum: No registered users and 58 guests
