It is currently Mon Sep 21, 2026 2:28 pm
Vehicle: 89 suzuki sierra
Post Posted: Tue Jan 16, 2018 6:12 pm
Hello all I am putting a g16a....yes i know its not the ideal motor, the question I have is will i need to do the sump conversion, i have 30mm body lift and 25mm longer shackles and have 30mm extended bumpstops.. I know I could trial fit it when i take the g13 out but i am trying to get the motor as close to bolt in as i can
Vehicle: G16b sierra
Post Posted: Tue Jan 23, 2018 1:51 pm
If it's a rear wheel drive motor then you shouldn't have to change the sump. Front wheel drive, ideally you would.
Post Posted: Tue Jan 23, 2018 7:01 pm
Thanks i was thinking i didnt have to change it but always like a second opinion. Yes it is a rear wheel drive g16a sorry should of said that
Vehicle: LWB tray top G13B
Post Posted: Thu Jul 05, 2018 9:25 pm
Hey mate, I've done heaps of searching but can't really find any answers.
G16A into where a G13A was, basically just get the adapter kit, modify sump (if needed) and you're good to go? is that all?
Vehicle: 86 SJ413 31's 1.6
Post Posted: Fri Jul 06, 2018 4:03 am
It will depend if your going to a 8 valve or 16 valve. If your going 8 valve and running your 1300 carb, then it’s pretty straight forward. But if your going for the 16 valve or injection on the 8 valve then there’s more wiring to deal with
Users browsing this forum: No registered users and 41 guests
