It is currently Mon Sep 21, 2026 4:04 am
Vehicle: 1992 Sierra sj70 Tin Top
Post Posted: Sun Apr 07, 2019 1:31 pm
i i just installed a 3k carb on my sj70 all went well started it up drove it about 300m and then tick tick tick tick tick started F#$K
i checked the timing its at -8 i pulled each plug one at a time but the tick still never went away, if i put the clutch in and out the ticks still there. i cant feel any hesitation and its idling ok
i removed the filter between carby and fuel pump and messed with the idle mix and still ticking, take rocker cover off and have a look at the tappers ?
I’m not really sure why Penrite is held in such regard other than parochialism. Boomers seem to love it though.
Vehicle: d20
Post Posted: Sun Apr 07, 2019 4:17 pm
Did the oil level go up? May be leaking fuel into the sump thinning out the oil.
Post Posted: Sun Apr 07, 2019 4:28 pm
i thought that could only happen with a fuel injected car ? this is an old g13ba carby.
Post Posted: Sun Apr 07, 2019 5:52 pm
No, opposite. The fuel pump on an efi car isn’t attached to the crank case. (Well they might be in some very late model direct injection cars but not a g motor.
Post Posted: Mon Apr 08, 2019 8:07 am
Oil Level looks fine, I took carby off and made sure the butterfly or something had not snapped off and fell into the manifold that all looks fine I'm 100 percent nothing dropped in it I had it sealed up the whole time. I'm starting to think tappet issue, will keep looking.
Post Posted: Tue Apr 09, 2019 9:52 am
noise seems to have pissed off at the moment, i do think the oil i got in her is a little thick 20w-60 and will be changing to 20w-50 soon but she was sitting for a month between a start so maybe something just needed a good run to get it going again.
Post Posted: Tue Apr 09, 2019 11:23 am
Sticking valve or may take a while to pump oil thru the tappet as it,s been sitting for a month.
Post Posted: Tue Apr 09, 2019 12:41 pm
Use the correct weight oil which is 15w40
Users browsing this forum: No registered users and 67 guests
