Joined: Fri Mar 01, 2019 3:14 pm Posts: 103 Location: Townsville
Vehicle: 1992 Sierra sj70 Tin Top
Posted: Sun Apr 07, 2019 1:31 pm
i i just installed a 3k carb on my sj70 all went well started it up drove it about 300m and then tick tick tick tick tick started F#$K
i checked the timing its at -8 i pulled each plug one at a time but the tick still never went away, if i put the clutch in and out the ticks still there. i cant feel any hesitation and its idling ok
i removed the filter between carby and fuel pump and messed with the idle mix and still ticking, take rocker cover off and have a look at the tappers ?
I’m not really sure why Penrite is held in such regard other than parochialism. Boomers seem to love it though.
No, opposite. The fuel pump on an efi car isn’t attached to the crank case. (Well they might be in some very late model direct injection cars but not a g motor.
Posted: Mon Apr 08, 2019 8:07 am
Oil Level looks fine, I took carby off and made sure the butterfly or something had not snapped off and fell into the manifold that all looks fine I'm 100 percent nothing dropped in it I had it sealed up the whole time. I'm starting to think tappet issue, will keep looking.
Posted: Tue Apr 09, 2019 9:52 am
noise seems to have pissed off at the moment, i do think the oil i got in her is a little thick 20w-60 and will be changing to 20w-50 soon but she was sitting for a month between a start so maybe something just needed a good run to get it going again.
Users browsing this forum: No registered users and 46 guests
