It is currently Mon Sep 21, 2026 12:57 am
Vehicle: Jeep Wrangler
Post Posted: Thu May 02, 2019 4:14 pm
Hi guys. First things first; this forum is great! Such a trove of info and ideas. After a couple of years lurking we’ve finally got a Suzuki.
Timing belt is overdue for replacement, I’m just wondering what else I should replace at the same time? 1992 Vitara manual 250,000km
Any other hot tips for changing the belt are welcome too.
Cheers!
Post Posted: Fri May 03, 2019 7:16 am
The only part of consequence associated with the timing belt is the water pump.
As for tips- mark the location of both pulleys relative to the head/block before you remove the belt and don’t move them at all when swapping the belt and you won’t have to time the motor from scratch.
Post Posted: Fri May 03, 2019 9:13 am
Rotate the engine to line up the timing marks before removing the old belt, and also replace the tensioner pulley - some folks like to replace the crank and cam seals whilst they are in there.
Post Posted: Fri May 03, 2019 7:03 pm
Awesome, thanks guys!
Post Posted: Fri May 03, 2019 7:21 pm
Definitely replace water pump and pulley. I would also have a good play with the crank bolt and make sure it is still mega tight with no play.
