The only part of consequence associated with the timing belt is the water pump.
As for tips- mark the location of both pulleys relative to the head/block before you remove the belt and don’t move them at all when swapping the belt and you won’t have to time the motor from scratch.
Rotate the engine to line up the timing marks before removing the old belt, and also replace the tensioner pulley - some folks like to replace the crank and cam seals whilst they are in there.
Users browsing this forum: Google [Bot] and 68 guests
