Ok,but if the cc capacity(combustion chamber volume) of the head of the 13B is smaller than the 16B the compression ratio will be too high whether it bolts on or not. If they both the same no problem,easy to measure.
_________________ Regards All from far Northern NSW.
Ive seen a die grinder used to create the extra valve clearances on pistons for the valves on 8v bottom end with gti 16 head. Seemed to work ok but would only attempt such things as a last resort
