It is currently Mon Sep 21, 2026 2:23 am
Vehicle: Suzuki Sierra SJ80
Post Posted: Mon Nov 04, 2019 11:58 am
Only reason I ask is I have access to a g16B vitara head intake dizzy wireing harness and ECU. Just to go to efi from carby.
Tia
Post Posted: Mon Nov 11, 2019 3:48 pm
yes it will bolt on.
Valves may hit the 8V pistons.
Ecu is tuned for a 1.6, not the smaller 1.3 so it may overfuel.
Post Posted: Wed Nov 13, 2019 8:44 am
Cheers mate just the info I was after appreciate it.
Vehicle: Coily.
Post Posted: Wed Nov 13, 2019 8:03 pm
Ok,but if the cc capacity(combustion chamber volume) of the head of the 13B is smaller than the 16B the compression ratio will be too high whether it bolts on or not.
If they both the same no problem,easy to measure.
Regards All from far Northern NSW.
Post Posted: Thu Nov 14, 2019 1:57 pm
you'll need jimny pistons, the have a dish in them and valve relief so the g16b on g13 block has the correct comp ratio and doesn't bend valves.
If you bored it out and use vit pistons or try relieving the 8v pistons you comp ratio will be way too high.
you'll need the jimny injectors too
Post Posted: Fri Nov 15, 2019 7:57 pm
Ive seen a die grinder used to create the extra valve clearances on pistons for the valves on 8v bottom end with gti 16 head. Seemed to work ok but would only attempt such things as a last resort
Post Posted: Sun Nov 17, 2019 5:03 am
Cylinder head volumes
32.2cc on the twin cam gti head
25.5 cc on the single cam g16b, g13bb head.
You could get away with cutting valve relief into the 8v pistons when using the gti head, but need to remove 7ccs to use the single came 16v head.
Users browsing this forum: No registered users and 64 guests
