It is currently Wed Nov 04, 2026 11:00 am
Post new topic Reply to topic  [ 823 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 28  Next
Post Posted: Wed Sep 14, 2011 10:29 am
Post Posted: Thu Sep 15, 2011 12:52 am
2stroker wrote:
Much to the amusement of the local kids I use my LJ50V to move my boat around the yard.
same as my old boat, you didnt happen to buy it off a bloke at Iluka did you?
Vehicle: 03 Jimny
Post Posted: Thu Sep 15, 2011 1:34 am
Has any one made a trailer/camper with some kind of coil setup?
How well would it go offroad/onroad then say a normal leaf spring setup?
Post Posted: Thu Sep 15, 2011 3:25 am
For the hassle, weight and complexity I decided any advantages were outweighed. There are lots of variations but for the most part I don't see much of a point apart from out-doing your mates. Leaves offer a degree of friction dampening so the right spring choice will mostly not require shocks.
There's usually many different opinions with this question and I'm sure someone will share their pro-coil opinion.
Post Posted: Thu Sep 15, 2011 4:22 am
A bloke in our club has a coiled home made camper,
I think its a suburu rear sub frame complete.
Think it even matches stud pattern of zooks.
Not a regular member, tho, so we could be another year before I see it again.
Vehicle: LWB Sierra & XL7
Post Posted: Fri Sep 16, 2011 8:44 am
Just a quickie guy's.
I'm thinking of buying a ute tub and turning it into a trailer, what do you reckon would the weight difference be compared to a 6x4 steel trailer.
Why ute tub? Already painted, already has lights. Just needs A frame, wiring, springs and axle. And they're CHEAP!!!!
'92 Vitara & Camper trailer
Post Posted: Fri Sep 16, 2011 8:39 pm
main draw backs with ute tubs is the weight and easier to damage, also end up with a higher centre of gravity. They can look cool though. If I built one of these again I'd strip and cut every unnecessary bit of metal out of it first as there's lots of double skins of sheet metal and tabs and shit.
Post Posted: Sun Sep 18, 2011 8:23 am
what length axle did everyone get that built their trailer from scratch to get close to the same as zuk wheel base?
Post Posted: Sun Sep 18, 2011 8:32 am
I bought an axle off a guy on ebay, who was going to build a boat trailer,
it was close enough, made up differece with wheel offsets.
Traile builders etc will make any length axle you ask for.
5 x 3'5 trailers usually work well.
Vehicle: 4wd
Post Posted: Sun Sep 18, 2011 10:47 am
What tents are you guys using? (maybe we need a thread for tents).
Watch out or you'll get sued.
Post Posted: Sun Sep 18, 2011 10:52 am
ebay cheapie, no name.
Sth African canvass, Chinese sewing, unsure of bed/base maker.
No longer stocks them, I bought last one.
Mine is just a cheapy off ebay, cost $700 i think
For the axle just find the wms to wms (wheel mounting surface) measurement and get a trailer place to make an axle to that size
Post Posted: Tue Sep 20, 2011 1:22 am
Hi just wanting to find out what some of you are towing.I was thinking of a 5x3 for the size otherwise going to a 6x4 as i will be towing it for camping trips with my 2005 jimny auto
Vehicle: 4wd
Post Posted: Tue Sep 20, 2011 1:57 am
I have a 6x4 and it's great. Not much wider then a Sierra, and it tows it fine.
Post Posted: Tue Sep 20, 2011 2:08 am
I've been looking at the same thing.
http://www.easytrailer.com.au/multifunc ... ilers.html
These look alright and arn't way over priced like the EARD trailers.
I was going to buy just the trailer and build the rest.
2005 Jimny "PaPa Smurf"
Post Posted: Wed Sep 21, 2011 8:32 am
Post Posted: Wed Sep 21, 2011 8:48 am
I'm rebuilding a old flip over camper with custom radius arms and panhard rod .
I looked at leaves but I couldn't get it high enough with them
It will be running 31'the same as the car so I have 2 spares and 2 more if shit hits the fan
I'm thinking it's going to be to heavy for the vit on long remote trips so I will have to get a ute for touring with the family I think and keep the vit for hard weekend trips
Vehicle: 03 Jimny
Post Posted: Fri Nov 18, 2011 6:05 am
Does any one know how to position the axle so it's not to far back that it will put force onto the draw bar and not to far forward or it will want to lift the hitch up?
Post Posted: Fri Nov 18, 2011 6:30 am
There is a percentage of box fore and aft of the axle specified by Qld transport which naturally puts an amount of down force on the ball. Can't remember the percentages and a lot of the trailers I see on the road don't adhere to this anyway.
Post Posted: Fri Nov 18, 2011 7:08 am
I found these helpful
http://www.angib.pwp.blueyonder.co.uk/t ... tear81.htm
http://www.angib.pwp.blueyonder.co.uk/t ... tear84.htm
Vehicle: 03 Jimny
Post Posted: Fri Nov 18, 2011 10:06 am
Thanks I'll have a good read. I'm not worried about the axle as yet cos I have much bigger problems now
Post Posted: Fri Nov 18, 2011 7:44 pm
Qld Transport single axle trailer self assessment PDF
Vehicle: 03 Jimny
Post Posted: Fri Nov 18, 2011 8:04 pm
Thanks mate. Since I'm building it from scratch I'll have to get a Manufacturer plate and put down "homemade" as the manufacturer so I could get it registered right?
Post Posted: Fri Nov 18, 2011 8:29 pm
I had to do that for Victorias laws.
Showing gross tare and home made,
plus had to stamp a chassis number into draw bar.
Unique number supplied by vic roads before building it.
Vehicle: 03 Jimny
Post Posted: Fri Nov 18, 2011 8:36 pm
Yea just read through kyzermattingley Jimny nd trailer thread. He pretty much explained it
Post Posted: Sat Nov 19, 2011 9:52 am
G'day AZers :helloo:
I'm getting a new trailer very soon and i want to have a battery on the trailer to run the fridge and lights at camp but still be able to charge the battery while on the move is this possible or do i need to run duel battery's in the GV?
Vehicle: 03 Jimny
Post Posted: Sat Nov 19, 2011 10:04 am
I was having a look into that same idea I'm pretty sure you run cable from your battery to a plug at the back ten the trailer plugs into the plug and charges the battery.
When I bought my dual battery isolator it had information about it all.
Post Posted: Sat Nov 19, 2011 10:11 am
7 pin plugs/cables have 2 spare wires in most cases,
some use for trailer brakes and a power lead, and/or reverse lights.
Can't see why you need battery on the trailer,
just need a power wire from a battery in the car.
I guess its whatever is easiest to fit.
Post Posted: Sat Nov 19, 2011 10:14 am
guess battery on trailer more useful if you want to run stuff when car aint connected to trailer....a charge wire would work same way...think its the blue wire normally
Post Posted: Sat Nov 19, 2011 10:41 am
Spot on :wink: and i don't want the battery on the GV to run flat and leave us stuck
I think this is what i need
Users browsing this forum: No registered users and 16 guests
