It is currently Fri Oct 02, 2026 12:49 am
Post new topic Reply to topic  [ 215 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post Posted: Sat Oct 15, 2011 6:32 am
So if you pinch the fuel return line do you get over 40psi? I'd take my 20 bucks now and use it to find an internal fuel leak like royce said pumps work or they don't so if pinching the fuel return doesn't allow pressure to build above 40 than I'd pull the tank out and look for a leak from pressure side of pump on inside of tank or if pinching does allow pressure to build than i'd look at pressure reg
Post Posted: Sat Oct 15, 2011 8:40 pm
we put the guage on the inlet hose to the fuel rail.
im still not 100% the guage is good, was an old guage. so im going to make a makeshift pump with a jar, some hose, and my air compressor to see if i can get the fuel reg to open that way.
MY BUILD THREAD HERE!!!!!
Post Posted: Sat Oct 15, 2011 9:18 pm
Was the gauge connected with a t-piece inline to the fuel rail inlet ? Could the car be started with the way you had the gauge set up?
Post Posted: Sat Oct 15, 2011 9:30 pm
nope. straight into the hose. nil-start
Post Posted: Sat Oct 15, 2011 11:54 pm
So the pump works, it builds up some pressure between the pump and fuel supply line under the bonnet excluding the fuel rail and pressure reg so fuel reg isn't causing the problem of low pressure. There must be a leak in the tank if its not pissing fuel out from under the car, some pumps have a pressure relief valve, this could be leaking or there is a crack in a plastic pipe or part of the assembly inside fuel tank. Can anyone back me up here?
The fact you said it can't even hold the little pressure its creating after the pump stops is telling me there is a leak
Post Posted: Sun Oct 16, 2011 12:37 am
i would put it down to a fuel pump..
as gman said the pump will have a pressure releif valve in it.
try calling
AFI
or
Nardek
dont have any details on them but can get them tomorrow for you.
they sell aftermarket coils, sensors, injectors all that kind of stuff. and majority of the time when you get them they are genuine parts anyway.
Post Posted: Sun Oct 16, 2011 1:18 am
thanks guys,
yeah that ph number would be great. ill drop the fuel tank later on and have a squizz
Post Posted: Sun Oct 16, 2011 2:05 am
just googled them.. hear are ther websites
AFI
Nardek
best to look on there webistes for the phone number. if you wait on me it wont be till tomorrow night
Vehicle: 2004 KJ jeep cherokee
Post Posted: Sun Oct 16, 2011 5:18 am
just a suggestion, if in doubt start at the manifold and remove one peice at a time, clean it and reinstall. rinse and repeat till u get in the fuel tank. It's long and tedious but you can diagnose any other fualts as well. good to hear it wasn't the crank pully pin. :)
If at first you don't suceed... lower your standar
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Oct 17, 2011 3:02 am
Any luck yet mate?
Post Posted: Mon Oct 17, 2011 3:04 am
nah mate, taken a day off from mucking with the car to do some housework. SWMBO was getting the shits. and so was i really. been raining pretty solidly too so not really good times to get under the car.
Hooking in tomorrow though.
Post Posted: Mon Oct 17, 2011 3:10 am
Sweet... :)
Post Posted: Mon Oct 17, 2011 3:18 am
just rang suzuki to get price on pump..... wait for it... 1700!!!!!!
think ill go with one of these or something. ill wait till i get it out 1st and confirm its rooted.
http://www.ebay.com.au/itm/FUEL-PUMP-SU ... 2c5ba68918
Post Posted: Mon Oct 17, 2011 3:31 am
1700 get stuffed.
An EFI fuel pump isn't anything special. As long as it fits, can flow enough and is of high enough pressure it will work.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Mon Oct 17, 2011 7:39 am
fuel pump filter in the tank
get down with the dirty little zukes
Post Posted: Mon Oct 17, 2011 8:23 am
um yes?? :blink:
Post Posted: Mon Oct 17, 2011 8:31 am
Did you try afi or nardek??
Post Posted: Mon Oct 17, 2011 8:32 am
not yet mate, havent dropped the tank yet. im doing a bit of research as to why the fuel reg isnt returning any fuel to tank.
Post Posted: Mon Oct 17, 2011 8:33 am
Nothing stopping you fitting an inline Z200 tho....
make a vn pump fit & fit an in line, $200.
Post Posted: Mon Oct 17, 2011 9:25 am
The fuel pressure regulator (one on the fuel rail) will only start to let fuel back to the tank once the required pressure has been reached, you have found with your dodgy pressure gauge even with the fuel pressure reg isolated by sticking the pressure gauge straight on the supply line from the pump and tank. That's why, the pump can't produce enough pressure either due to a fucked pump or leaky system as mentioned above
Post Posted: Mon Oct 17, 2011 10:32 am
ah of course, it all makes sense.
well once i get some empty jerry cans ill drain the tank and have a squizz at the pump. all the lines look ok. Once pump is disconnected ill blow compressed air down the line also.
Post Posted: Tue Oct 18, 2011 1:46 am
ok fans,
after a LOT of mucking around i got the tank out on my own (get help if you plan on doing yaself)
got the pump assy out and dismantled as you see here
(easy to do)
and the only thing i could spot wrong with the whole thing was this.
i dont think it was sitting in its pipe very well either.
so there you go. now to find a new grommet and see if that fixes things.....
Post Posted: Tue Oct 18, 2011 2:08 am
fingers crossed. :wink:
Post Posted: Tue Oct 18, 2011 2:17 am
hope so. just rang zooki, they dont supply the rubber bit (typical) so no luck there. ive got the assy back together and jammed the pump up there a bit better, it practically fell out before. considering taking off the filter and putting a generic 3 dollar inline filter from supergays in.
might try pirtek or an o-ring place
Post Posted: Tue Oct 18, 2011 2:25 am
which bit is the filter?
google the bosch part number on the pump and see if it doesnt lead you to a seal somewhere
Post Posted: Tue Oct 18, 2011 2:28 am
the filter is the little teabag thing. looks pretty useless.
I might buy a new one anyway as it would protect the pump and put an inline in the engine bay...
Post Posted: Tue Oct 18, 2011 2:37 am
A quick google result for you:
Bosch 0580454094 - $108 from Trade Parts.
TRADE PARTS
Level 1, 50 Whiting St.
Artarmon
NSW 2064
Australia
phone: +61 2 9439 9900
fax: +61 2 9439 3912
email: info@tradeparts.com.au
Hope this helps. Its certainly better than Suzuki's $1700 quote.
Post Posted: Tue Oct 18, 2011 2:41 am
yeah i saw them. zook said 600 just for pump, the whole thing was 1700.
Just need the rubber. not pump.
Post Posted: Tue Oct 18, 2011 2:43 am
wholly crap. 300 bucks for the filter from suzuki.... even the sheila on the phone said im probably never gonna call her again.
Vehicle: 2001 Jimny M13A
Post Posted: Tue Oct 18, 2011 2:55 am
Suzistore fuel pump
or maybe stack some standard o rings - dodgy as but may work.
Users browsing this forum: Google [Bot] and 159 guests
