Print view
Previous topic | Next topic
| Author |
Message |
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Sat Jul 23, 2011 11:23 pm |
SWB LJ's
Highway-Star (Anita) - LJ80V-II - 0.727 - 1112 - 35.871
(31x10.5's on 15x8s, RUF front, 2" EFS back)
SWB Sierras
SierraDan - SWB WT -0.639 - 1055 - 34.03
(31x10.5's on 15x8s, 2" lift.)
JrZook - SWB WT - 0.644 - 1037 - 34.56
(30x9.5's on 15x7s, WT, RUF, Custom springs)
Highway-Star (Tara) - SJ70Q - 0.674 - 1071 - 34.55
(31x10.5's on 15x7s, RUF front, 2" EFS back)
alien - SWB WT - 0.680 - 1140 - 36.774
(31x10.5's on 15x7-38, SPOA Lux Fronts all round w/ lux shackles)
LWB Sierra
TSOR shop ute - 0.715 - 1170 - 35.45
linked, coilovers - 33x12.5 - no B/L
SWB Vitaras
atari4x4 - SV420 Vitara -0.570 - 1037 - 33.51
(31x10.5's on 15x7s, Calmini 3" lift, 2" body lift)
NinjaMoses - SV420 Vitara - 0.597 - 1044 - 32.72
(235/85/16s on 16x7s, 2" body lift, 2" coil spacers)
LWB Vitaras
Vits93 - SE416 Vitara - 0.636 - 1070 - 34.51
(31x10.5 on 15x7 -13, Calmini 3" plus 2" body lift)
Jimny
Zukenutter - Jimny - 0.651 - 1058 - 37.12
(235/75/15 (28.5) on 15x7, 3.5" Susp. lift)
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Sun Jul 24, 2011 12:54 am |
Teracis wrote: The idea here is that the higher your height/width number, the more likely it's going to be to tip over compared to the others yes?
Its a crude way to look at it, as COG plays its part in the equation also. But for the purposes of this comparison I can't see any other way to get the point across.
_________________ 2013 GV 1998 SV420 ute
zukenutter
 Posted: Sun Jul 24, 2011 1:07 am |
Fatzook wrote: Teracis wrote: The idea here is that the higher your height/width number, the more likely it's going to be to tip over compared to the others yes? Its a crude way to look at it, as COG plays its part in the equation also. But for the purposes of this comparison I can't see any other way to get the point across.
^^^ What he said
rpmwrx
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1303 Location: Geelong
 Posted: Sun Jul 24, 2011 2:44 am |
SWB LJ's
SWB Sierras
RPMWRX- SWB WT - 0.724 - 1225 - 37.12
(33x10.5's on 15x8 -30, SPOA, WT, OME Leafs, Stock Shackles, 2" BL)
LWB Sierra
SWB Vitaras
LWB Vitaras
Jimny
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Sun Jul 24, 2011 6:50 am |
zukenutter wrote: Fatzook wrote: Teracis wrote: The idea here is that the higher your height/width number, the more likely it's going to be to tip over compared to the others yes? Its a crude way to look at it, as COG plays its part in the equation also. But for the purposes of this comparison I can't see any other way to get the point across. ^^^ What he said
I get that it's crude, I was just checking that was the comparison we were going for here. Obviously if one of us has some luggage rack or something with 100kg at the highest point on the vehicle it's not going to be a very good indicator, but for those with quite similar setups that differ by tyre size and offset it would be a reasonable comparison one could suggest.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Sun Jul 24, 2011 7:30 am |
ok new car
still unused so likely to settle a bit from this
handle av = 1057mm
width 1705mm
real tyre height at 10 psi 33.4 inches
swb, full ruf custom shackle mounts, ext shackles rolling on 15 x 8's and 34's
zukenutter
 Posted: Sun Jul 24, 2011 7:41 am |
Teracis wrote: zukenutter wrote: Fatzook wrote: Teracis wrote: The idea here is that the higher your height/width number, the more likely it's going to be to tip over compared to the others yes? Its a crude way to look at it, as COG plays its part in the equation also. But for the purposes of this comparison I can't see any other way to get the point across. ^^^ What he said I get that it's crude, I was just checking that was the comparison we were going for here. Obviously if one of us has some luggage rack or something with 100kg at the highest point on the vehicle it's not going to be a very good indicator, but for those with quite similar setups that differ by tyre size and offset it would be a reasonable comparison one could suggest.
Even differences like a body lift will affect this so lets not go there.
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Tue Aug 09, 2011 5:13 am |
SWB LJ's
SWB Sierras
ajsr - SWB WT - 0.619 - 1057 - 31.64
(full ruf custom shackle mounts, ext shackles rolling on 15 x 8's and 34's)
(33x11.5's on 15x8 -30, SPOA, WT, OME Leafs, Stock Shackles, 2" BL)
LWB Sierra
SWB Vitaras
LWB Vitaras
Jimny
_________________ Lil Foot!
http://tiny.cc/gtsw1
JrZook
 Posted: Tue Aug 09, 2011 5:14 am |
ajsr's is a super wide low rider!!
Does anyone have stock vehicles that they would be able to measure up and add to this thread for comparison sake?
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Tue Aug 09, 2011 7:10 am |
Thats pretty solid for a zook on 34's haha!
_________________ mlm
ajsr
 Posted: Tue Aug 09, 2011 7:23 am |
JrZook wrote: ajsr's is a super wide low rider!! Does anyone have stock vehicles that they would be able to measure up and add to this thread for comparison sake?
Gwagen has built one much lower on 35X13 krawlers, it may not be wider but is definately lower
JrZook
 Posted: Tue Aug 09, 2011 12:15 pm |
ajsr wrote: JrZook wrote: ajsr's is a super wide low rider!! Does anyone have stock vehicles that they would be able to measure up and add to this thread for comparison sake? Gwagen has built one much lower on 35X13 krawlers, it may not be wider but is definately lower
Measurements would be great!
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Tue Aug 09, 2011 12:16 pm |
i should have 35s on the LJ by the weekend
JrZook
 Posted: Tue Aug 09, 2011 12:20 pm |
tanshi wrote: i should have 35s on the LJ by the weekend
Can I test your old 33's and see how much more cutting is required on lil foot
tanshi
 Posted: Tue Aug 09, 2011 12:22 pm |
i'll take some measurements on both sets ot tyres
Moph
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
 Posted: Tue Aug 09, 2011 1:20 pm |
--- SWB LJ ---
--- SWB Sierra ---
Moph - 93 SWB WT hardtop - 0.663 - 1060 - 34.19
(31x10.5's on 15x7 -15, 2" BL, half RUF, 2" OME's rear, custom hangers, +30mm shackles)
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
(235/75/15 (28.5) on 15x7, 3.5" Susp. lift)[/quote]
JrZook
 Posted: Tue Aug 09, 2011 11:56 pm |
--- SWB LJ ---
--- SWB Sierra ---
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
Cheers Moph, I put yours in order. That's also a pretty darn low setup for a 2" B/L vehicle!!
Moph
Vehicle: 93 Sierra
 Posted: Wed Aug 10, 2011 1:52 am |
Ah sorry - missed that we were doing it in order of tippiness. It probably will lift a tad once I fit +30mm shackles to the rear too, which I need to do because the springs have just sagged enough that the driver's side rear shackle has started inverting
I lifted the driver's rear to match the passenger rear using a jack for the measurements though, so shouldn't be out by much from it's proper position.
bohuler
Joined: Wed Nov 10, 2010 9:18 am Posts: 1376 Location: Avonsleigh, Victoria
 Posted: Wed Aug 10, 2011 3:12 am |
Another LWB Sierra
Bohuler (Turtle Express) LWB N/T 0.738 - 1020 - 37.78
215/75/15 on 15x5.5, stock front, 2" shackles and load coils in rear.
I out the tire size down as 27 inch, wih 90,000 on the tires i think that have worn about 1/2 an inch
JrZook
 Posted: Wed Aug 10, 2011 4:01 am |
JrZook wrote: --- SWB LJ ---
Highway-Star (Anita) - LJ80V-II - 0.727 - 1112 - 35.871 (31x10.5's on 15x8s, RUF front, 2" EFS back)
--- SWB Sierra ---
ajsr - SWB WT - 0.619 - 1057 - 31.64 (full ruf custom shackle mounts, ext shackles rolling on 15 x 8's and 34's)
SierraDan - SWB WT -0.639 - 1055 - 34.03 (31x10.5's on 15x8s, 2" lift.)
JrZook - SWB WT - 0.644 - 1037 - 34.56 (30x9.5's on 15x7s, WT, RUF, Custom springs)
Moph - 93 SWB WT hardtop - 0.663 - 1060 - 34.19 (31x10.5's on 15x7 -15, 2" BL, half RUF, 2" OME's rear, custom hangers, +30mm shackles)
Highway-Star (Tara) - SJ70Q - 0.674 - 1071 - 34.55 (31x10.5's on 15x7s, RUF front, 2" EFS back)
alien - SWB WT - 0.680 - 1140 - 36.774 (31x10.5's on 15x7-38, SPOA Lux Fronts all round w/ lux shackles)
RPMWRX- SWB WT - 0.724 - 1225 - 37.12 (33x11.5's on 15x8 -30, SPOA, WT, OME Leafs, Stock Shackles, 2" BL)
--- LWB Sierra ---
TSOR shop ute - 0.715 - 1170 - 35.45 linked, coilovers - 33x12.5 - no B/L
Bohuler (Turtle Express) LWB N/T 0.738 - 1020 - 37.78 215/75/15 on 15x5.5, stock front, 2" shackles and load coils in rear.
--- SWB Vitara ---
atari4x4 - SV420 Vitara -0.570 - 1037 - 33.51 (31x10.5's on 15x7s, Calmini 3" lift, 2" body lift)
NinjaMoses - SV420 Vitara - 0.597 - 1044 - 32.72 (235/85/16s on 16x7s, 2" body lift, 2" coil spacers)
--- LWB Vitara ---
Vits93 - SE416 Vitara - 0.636 - 1070 - 34.51 (31x10.5 on 15x7 -13, Calmini 3" plus 2" body lift)
--- Jimny ---
Zukenutter - Jimny - 0.651 - 1058 - 37.12 (235/75/15 (28.5) on 15x7, 3.5" Susp. lift)
Thanks for the info.
Guys please append your measurements to this post or the latest update of the list. Ie copy and paste this post into your reply and add your measurements. They are ordered by H/W ratio (first column) so add yours in where it's order is.
Cheers Dan
tanshi
 Posted: Wed Aug 10, 2011 4:29 am |
Dan the thread Nazi
bohuler
 Posted: Wed Aug 10, 2011 6:22 am |
I was struggling nuff just working out da numbers  I was sure someone would sort the rest out for me
_________________ Life's short, fiddle with your willy while you can
JrZook
 Posted: Wed Aug 10, 2011 10:09 am |
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
 Posted: Thu Aug 11, 2011 2:59 am |
--- SWB Sierra ---
boostedbrick - SWB WT - 0.711 - 1100 - 37.93 (235x75 15 on 15x7 -12, RUF with M/L on custom fronts, custom rears with 3/4 Ellip(shouldnt effect static height))
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
Hope mine settles a few more inchs, other wise its going to fall over...
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
Vehicle: 03 Jimny
 Posted: Fri Aug 12, 2011 6:36 am |
--- SWB LJ ---
--- SWB Sierra ---
zooky08 - SWB NT - 0.7 - 1120 - 37.33
(30x9.5 15 on 5x7 0 offset, RUF, wt conversion, 40mm spring, 2" body lift
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
atari4x4
 Posted: Thu Aug 18, 2011 3:11 am |
I just updated mine, measuring to the actual door handle as per Ninjamoses.
[hr]
--- SWB LJ ---
--- SWB Sierra ---
--- LWB Sierra ---
--- SWB Vitara ---
atari4x4 - SV420 Vitara -0.589 - 1072 - 34.58
--- LWB Vitara ---
--- Jimny ---
tanshi
 Posted: Sat Aug 20, 2011 7:17 am |
94BAZOOKA
Joined: Mon Jan 17, 2011 8:40 am Posts: 537 Location: central coast NSW
 Posted: Tue Sep 06, 2011 8:23 pm |
Sierra - 1325 - 37.85
1900 - 0.69
Spoa Hilux springs extended shackles l/c diffs
35" trepadors on 15x8
_________________ F#%ING [P] PLATER
tanshi
 Posted: Tue Sep 06, 2011 10:45 pm |
boostedbrick
Vehicle: 2018 DMAX
 Posted: Tue Sep 06, 2011 11:22 pm |
Users browsing this forum: No registered users and 73 guests
