It is currently Fri Sep 25, 2026 12:09 am
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Sat Jul 23, 2011 11:23 pm
SWB LJ's
Highway-Star (Anita) - LJ80V-II - 0.727 - 1112 - 35.871
(31x10.5's on 15x8s, RUF front, 2" EFS back)
SWB Sierras
SierraDan - SWB WT -0.639 - 1055 - 34.03
(31x10.5's on 15x8s, 2" lift.)
JrZook - SWB WT - 0.644 - 1037 - 34.56
(30x9.5's on 15x7s, WT, RUF, Custom springs)
Highway-Star (Tara) - SJ70Q - 0.674 - 1071 - 34.55
(31x10.5's on 15x7s, RUF front, 2" EFS back)
alien - SWB WT - 0.680 - 1140 - 36.774
(31x10.5's on 15x7-38, SPOA Lux Fronts all round w/ lux shackles)
LWB Sierra
TSOR shop ute - 0.715 - 1170 - 35.45
linked, coilovers - 33x12.5 - no B/L
SWB Vitaras
atari4x4 - SV420 Vitara -0.570 - 1037 - 33.51
(31x10.5's on 15x7s, Calmini 3" lift, 2" body lift)
NinjaMoses - SV420 Vitara - 0.597 - 1044 - 32.72
(235/85/16s on 16x7s, 2" body lift, 2" coil spacers)
LWB Vitaras
Vits93 - SE416 Vitara - 0.636 - 1070 - 34.51
(31x10.5 on 15x7 -13, Calmini 3" plus 2" body lift)
Jimny
Zukenutter - Jimny - 0.651 - 1058 - 37.12
(235/75/15 (28.5) on 15x7, 3.5" Susp. lift)
Post Posted: Sun Jul 24, 2011 12:54 am
Teracis wrote:
The idea here is that the higher your height/width number, the more likely it's going to be to tip over compared to the others yes?
Its a crude way to look at it, as COG plays its part in the equation also. But for the purposes of this comparison I can't see any other way to get the point across.
Post Posted: Sun Jul 24, 2011 1:07 am
^^^ What he said
Post Posted: Sun Jul 24, 2011 2:44 am
SWB LJ's
SWB Sierras
RPMWRX- SWB WT - 0.724 - 1225 - 37.12
(33x10.5's on 15x8 -30, SPOA, WT, OME Leafs, Stock Shackles, 2" BL)
LWB Sierra
SWB Vitaras
LWB Vitaras
Jimny
Vehicle: Daisy
Post Posted: Sun Jul 24, 2011 6:50 am
^^^ What he said
I get that it's crude, I was just checking that was the comparison we were going for here. Obviously if one of us has some luggage rack or something with 100kg at the highest point on the vehicle it's not going to be a very good indicator, but for those with quite similar setups that differ by tyre size and offset it would be a reasonable comparison one could suggest.
Post Posted: Sun Jul 24, 2011 7:30 am
ok new car
still unused so likely to settle a bit from this
handle av = 1057mm
width 1705mm
real tyre height at 10 psi 33.4 inches
swb, full ruf custom shackle mounts, ext shackles rolling on 15 x 8's and 34's
Post Posted: Sun Jul 24, 2011 7:41 am
Even differences like a body lift will affect this so lets not go there. 8O :D
Post Posted: Tue Aug 09, 2011 5:13 am
SWB LJ's
SWB Sierras
ajsr - SWB WT - 0.619 - 1057 - 31.64
(full ruf custom shackle mounts, ext shackles rolling on 15 x 8's and 34's)
(33x11.5's on 15x8 -30, SPOA, WT, OME Leafs, Stock Shackles, 2" BL)
LWB Sierra
SWB Vitaras
LWB Vitaras
Jimny
Lil Foot!
Post Posted: Tue Aug 09, 2011 5:14 am
ajsr's is a super wide low rider!! 8)
Does anyone have stock vehicles that they would be able to measure up and add to this thread for comparison sake?
Lil Foot!
Post Posted: Tue Aug 09, 2011 7:10 am
Thats pretty solid for a zook on 34's haha!
Post Posted: Tue Aug 09, 2011 7:23 am
Gwagen has built one much lower on 35X13 krawlers, it may not be wider but is definately lower
Post Posted: Tue Aug 09, 2011 12:15 pm
Measurements would be great!
Lil Foot!
Post Posted: Tue Aug 09, 2011 12:16 pm
i should have 35s on the LJ by the weekend
Post Posted: Tue Aug 09, 2011 12:20 pm
:blink:
Can I test your old 33's and see how much more cutting is required on lil foot :lol:
Lil Foot!
Post Posted: Tue Aug 09, 2011 12:22 pm
i'll take some measurements on both sets ot tyres
Vehicle: 93 Sierra
Post Posted: Tue Aug 09, 2011 1:20 pm
--- SWB LJ ---
--- SWB Sierra ---
Moph - 93 SWB WT hardtop - 0.663 - 1060 - 34.19
(31x10.5's on 15x7 -15, 2" BL, half RUF, 2" OME's rear, custom hangers, +30mm shackles)
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
(235/75/15 (28.5) on 15x7, 3.5" Susp. lift)[/quote]
Post Posted: Tue Aug 09, 2011 11:56 pm
--- SWB LJ ---
--- SWB Sierra ---
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
Cheers Moph, I put yours in order. That's also a pretty darn low setup for a 2" B/L vehicle!! 8)
Lil Foot!
Vehicle: 93 Sierra
Post Posted: Wed Aug 10, 2011 1:52 am
Ah sorry - missed that we were doing it in order of tippiness. It probably will lift a tad once I fit +30mm shackles to the rear too, which I need to do because the springs have just sagged enough that the driver's side rear shackle has started inverting :lol:
I lifted the driver's rear to match the passenger rear using a jack for the measurements though, so shouldn't be out by much from it's proper position.
Post Posted: Wed Aug 10, 2011 3:12 am
Another LWB Sierra :D
Bohuler (Turtle Express) LWB N/T 0.738 - 1020 - 37.78
215/75/15 on 15x5.5, stock front, 2" shackles and load coils in rear.
I out the tire size down as 27 inch, wih 90,000 on the tires i think that have worn about 1/2 an inch :lol:
Post Posted: Wed Aug 10, 2011 4:01 am
JrZook wrote:
--- SWB LJ ---
--- SWB Sierra ---
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
Thanks for the info.
Guys please append your measurements to this post or the latest update of the list.
Ie copy and paste this post into your reply and add your measurements. They are ordered by H/W ratio (first column) so add yours in where it's order is.
Cheers Dan
Lil Foot!
Post Posted: Wed Aug 10, 2011 4:29 am
Dan the thread Nazi :)
Post Posted: Wed Aug 10, 2011 6:22 am
I was struggling nuff just working out da numbers :D I was sure someone would sort the rest out for me :lol:
Post Posted: Wed Aug 10, 2011 10:09 am
No probs mate.
Just keeping the thread in order :)
Lil Foot!
Vehicle: 2018 DMAX
Post Posted: Thu Aug 11, 2011 2:59 am
JrZook wrote:
--- SWB LJ ---
--- SWB Sierra ---
boostedbrick - SWB WT - 0.711 - 1100 - 37.93
(235x75 15 on 15x7 -12, RUF with M/L on custom fronts, custom rears with 3/4 Ellip(shouldnt effect static height))
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
Hope mine settles a few more inchs, other wise its going to fall over...
Post Posted: Fri Aug 12, 2011 6:36 am
--- SWB LJ ---
--- SWB Sierra ---
zooky08 - SWB NT - 0.7 - 1120 - 37.33
(30x9.5 15 on 5x7 0 offset, RUF, wt conversion, 40mm spring, 2" body lift
--- LWB Sierra ---
--- SWB Vitara ---
--- LWB Vitara ---
--- Jimny ---
Post Posted: Thu Aug 18, 2011 3:11 am
I just updated mine, measuring to the actual door handle as per Ninjamoses.
[hr]
--- SWB LJ ---
--- SWB Sierra ---
--- LWB Sierra ---
--- SWB Vitara ---
atari4x4 - SV420 Vitara -0.589 - 1072 - 34.58
--- LWB Vitara ---
--- Jimny ---
Post Posted: Sat Aug 20, 2011 7:17 am
Post Posted: Tue Sep 06, 2011 8:23 pm
Sierra - 1325 - 37.85
1900 - 0.69
Spoa Hilux springs extended shackles l/c diffs
35" trepadors on 15x8
F#%ING [P] PLATER
 Profile YIM
Post Posted: Tue Sep 06, 2011 10:45 pm
Vehicle: 2018 DMAX
Post Posted: Tue Sep 06, 2011 11:22 pm
Users browsing this forum: Bing [Bot] and 139 guests
