It is currently Sat Oct 10, 2026 1:14 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Post Posted: Mon Aug 08, 2011 10:58 am
SierraDan wrote:
it can run 180.
Did it two weekends ago.
EDIT: not well mind you.
so you are trying to tell me you had an engine running with the plugs firing at the end of the exhaust stroke when the inlet valves are just starting to open?\
You have totally proven all that is known about engines to be false and should perhaps contact Ferrari about a position in their development labs
Post Posted: Mon Aug 08, 2011 11:00 am
Sorry. Trying. You wouldnt have been able to drive around the block or anything.
I experienced this. Igniting on the exhaust stroke, sometimes coughing and turning over a couple of times giving you the idea it's almost going to start. Better to check than ignore it because it wasn't mentioned in a post.
jonno_racing wrote:
issue is, it wont go... tried to start off the key and it felt like a flat battery, realy struggling when motor comes round onto compression. we tried to tow start it with no luck. it kind of fired but would not start or make any power...
Post Posted: Mon Aug 08, 2011 11:28 am
Check your earths. It could also be your shifter bush. Failing that do a 4AGE swap. Hi Royce :helloo:
Here is some info about the pulley orientation with regard to the E and I marks. It's for a 16v 1600, but I can't see how it would be different to a g13.
Post Posted: Tue Aug 09, 2011 10:32 am
thanks mate
Post Posted: Wed Aug 10, 2011 3:41 am
fixed..
dan i would like a colla rockstar pls your wrong..
the cam was locked in the wrong hole.
all fixed and marked the correct timing mark with some "nissan red" paint.
Post Posted: Wed Aug 10, 2011 6:47 am
jonno_racing wrote:
fixed..
:oops:
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Users browsing this forum: No registered users and 201 guests
