| Author |
Message |
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Wed Nov 09, 2011 11:18 am |
^^^ I thought you had a panhard rod on your setup up Cam?
_________________ Tell my arse, he actually gives a crap!
bakerboy
Joined: Sun Oct 25, 2009 10:30 pm Posts: 2291 Location: Perth
 Posted: Wed Nov 09, 2011 11:21 am |
nah it didnt help the erratic handling at speed (anything over 25 i guess) so it was removed
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Wed Nov 09, 2011 11:39 am |
nah mine was fine with no track bar, no hopping at all just mega body roll
when cornering with the pins removed. Other than that not really noticeable
_________________ ...
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Wed Nov 09, 2011 11:46 am |
Interesting. What about lateral diff movement? No noticeable difference to having the fixed hangers?
_________________ Lil Foot!
http://tiny.cc/gtsw1
MrRocky
 Posted: Wed Nov 09, 2011 12:12 pm |
zero, but u notice i had a stop just before the bolt attatching the leaf
i was a bit worried about the strain on the bolt and lateral movement so when the leaf contacted the stop it remained square also
ablouse
Joined: Thu Oct 27, 2011 1:11 pm Posts: 58 Location: perth
Vehicle: ute
 Posted: Wed Nov 09, 2011 12:56 pm |
would running a heavier spring on top or maybe a spring pack force the bottom spring flex more? i get loads of droop but not much movement in that full spring, ive also noticed with the rear unlocked the lower tyre seems to loose traction really easy, if the main spring was flexing more would that aid traction? of course it works fine locked up. Im definatly going to limit that top springs travel for road use it looks like a trophy truck going around corners that set up with the pins below the spring when the spring goes back up to normal position hard up against the chassis does it slide in cleanly between those brakets, i was thinking of using a u bolt but you system looks easier to remove
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5944 Location: Northcliffe, W.A.
 Posted: Wed Nov 09, 2011 2:04 pm |
SSSIERA wrote: CairnsZook wrote: SSSIERA wrote: except for being able to do it legaly, not voiding insurance and not getting yellow stickers! You just don't get it do you... Any non-approved modifications to suspension are illegal. Just because you put a pin in there doesn't mean diddly-squat when it comes to legalities and insurance.  ill do a quick drawing. i mean a fully bolt of top spring, that u put back on b4 u go 4wding, then unleash it when u get ofroad
It doesn't matter mate, mods like that to your suspension are a big no no.
SSSIERA
Joined: Tue Mar 22, 2011 1:26 pm Posts: 1770 Location: Perth's RUF
 Posted: Wed Nov 09, 2011 2:19 pm |
side view
rear view
red bolts come undone, and the top leaf comes of for around town, say im going powerlines on a saterday morning, i bolt it on, and pin the spring pack in place. get to the powerlines, pull the pin and flex away. finish the track, pin goes back in, drive home, unbolt, put in the shed, and the car is no longer ilegal (for elliptical)
_________________ THINKING BEFORE POSTING!!!
sideways
 Posted: Wed Nov 09, 2011 2:41 pm |
About as good flex as you'l get out of leaves.
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
 Posted: Wed Nov 09, 2011 10:22 pm |
MrRocky wrote: nah mine was fine with no track bar, no hopping at all just mega body roll when cornering with the pins removed. Other than that not really noticeable
Mine behaves much the same.. Body roll is definitely there but I don't drive it fast enough for it to be a negative. Rear springs are stiffer than I would run otherwise but work well... Minimal lateral movement..
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Wed Nov 09, 2011 10:32 pm |
No one has said it yet that i can see. you need to get the front end working mor before you get more out of the rear. do a ruf then this but in saying that the unloaded tyre will slip no matter how much fully sic flex you have. LOCKERS ARE BETTER THAN FLEX
ablouse
Vehicle: ute
 Posted: Wed Nov 09, 2011 10:33 pm |
i have loads af lateral movement ive just ordered some new shackles hoping that will solve it
boostedbrick
Vehicle: 2018 DMAX
 Posted: Wed Nov 09, 2011 10:35 pm |
SSSIERA wrote: side view  rear view  red bolts come undone, and the top leaf comes of for around town, say im going powerlines on a saterday morning, i bolt it on, and pin the spring pack in place. get to the powerlines, pull the pin and flex away. finish the track, pin goes back in, drive home, unbolt, put in the shed, and the car is no longer ilegal (for elliptical)
Your talking about applying this to wide track, have you considered mounting the other end of the top leaf to the chassis? In a WT the only thing that is down there is the bump stop... I cant see any way of easily bolting on and off a mount to hold the spring..
Top spring length will also be an issue.. the eye of the bottom spring needs to be behind the chassis mount, so that you have adequate shackle angle with normal use.. This means the top eye will be significantly forward of the bottom eye(because you wish to keep the chassis mount). This will restrict the amount of travel you get out of this leaf and make the rear handle very poorly. The very short length of the top spring will also affect travel here... Seems like alot of work for minimal gain and its still illegal if you get pulled over.
And for the lockers are better than flex comment. Yes lockers are better at gaining ability, but maybe we don't want lockers.. With my current setup, small tyres, no lockers or gears and decent travel, I can drive up tracks I couldn't drive locked on 33's
ablouse
Vehicle: ute
 Posted: Wed Nov 09, 2011 10:36 pm |
sideways wrote: About as good flex as you'l get out of leaves.
is that a home made shackle? does it twist? looks very interesting
ablouse
Vehicle: ute
 Posted: Wed Nov 09, 2011 10:43 pm |
Brett wrote: No one has said it yet that i can see. you need to get the front end working mor before you get more out of the rear. do a ruf then this but in saying that the unloaded tyre will slip no matter how much fully sic flex you have. LOCKERS ARE BETTER THAN FLEX
i realize an unloaded tyre will has less traction, mine is breaking loose with enough wieght on it to still bag with 16psi in it, granted there is practically no weight over the rear just never experienced this in in my coily
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Thu Nov 10, 2011 12:14 am |
ablouse wrote: sideways wrote: About as good flex as you'l get out of leaves.  is that a home made shackle? does it twist? looks very interesting
Superior engineering drop shackle from memory.
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Thu Nov 10, 2011 1:01 am |
Red89 wrote: ablouse wrote: sideways wrote: About as good flex as you'l get out of leaves.  is that a home made shackle? does it twist? looks very interesting Superior engineering drop shackle from memory.
This is a perfect example of what not to do. The vehicle has terrible balance. Just look at the front end.....it may aswell be welded in place.
I realise it can be hard to get travel from the rear at times, but having 10 times less spring rate than the front is not what I would call fixing the problem.
_________________ 2013 GV 1998 SV420 ute
bakerboy
 Posted: Thu Nov 10, 2011 2:27 am |
This is our ghetto fab, give you perspective of the rear that I posted before
4x4zook
Joined: Wed Jun 15, 2011 2:25 am Posts: 151 Location: australia port augus
 Posted: Mon Nov 14, 2011 6:56 am |
what about the fuell filler, anyone got pics of how they have moved it
LAY80N
Joined: Tue Jul 28, 2009 11:30 pm Posts: 455 Location: Newcastle NSW
Vehicle: I drive your mum
 Posted: Mon Nov 14, 2011 7:52 am |
Fatzook wrote: Red89 wrote: ablouse wrote: sideways wrote: About as good flex as you'l get out of leaves.  is that a home made shackle? does it twist? looks very interesting Superior engineering drop shackle from memory. This is a perfect example of what not to do. The vehicle has terrible balance. Just look at the front end.....it may aswell be welded in place. I realise it can be hard to get travel from the rear at times, but having 10 times less spring rate than the front is not what I would call fixing the problem.
And FATZOOK is the winner of this thread. Yeah it looks cool (to some) on a ramp, but go climp a steep/vert ledge with a stiff front and flexy rear and you will get the idea. Big twist, wheel up, then the view gets kinda strange with the sky where the ground should be. IMHO dont stress about getting more flex, lock the rig, gear it and learn how to drive. Rigs with unbalanced and poorly thought out roll stiffness front to rear are worse to drive than a rig with limited flex.
Layto....
MrRocky
 Posted: Mon Nov 14, 2011 8:45 am |
when i did my ruf, i found it made the front end stay much more level while the suspension did its thing, also noticed an increase in rear flex too.
i had to play with the shackle angles and springs to get the best result for my driving style, the end result was a predictable stable amount of flex.
