It is currently Sat Nov 14, 2026 10:18 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Vehicle: 95 Sierra Soft top
Post Posted: Sun Mar 04, 2012 6:34 pm
Its still of the road so not yet, ill loook into lights ones all the big stuff is out of the way
Post Posted: Sun Mar 04, 2012 7:18 pm
http://www.ebay.com.au/itm/SEALED-BEAMS ... 3a6d831992
These would be my choice or something similar. 75w high and 50w low.
Vehicle: 97 Coliy, 30s, Lift, etc.
Post Posted: Fri Mar 09, 2012 6:07 pm
Yes, I tried them out.
I believe I fitted the sealing boot at the rear of the lights correctly, but both lights ended up getting water inside them within several weeks of owning them. One was 1/4 full of water and the reflector instantly rusted away to the waterline, and the other was just filled with constant moisture.
The lights were fitted with an aftermarket HID kit, and the beam pattern was horrendous. The lights were aimed right down so as to not dazzle any oncoming traffic and were plenty bright but light quality wise I'd definitely have been better off with a good quality Halogen upgrade kit. The HID Kit died shortly after (ignitors packed it in).
The halos are not particularly bright. They're okay in low light, but they're ultimately made up of 4 5mm LEDs and don't produce even illumination. The hole for the halo power cable was poorly sealed when I received the lights and needed additional sealant, but the water that killed them came in around globes.
The tabs on the support rings also didn't line up with the notches on the light, and some of the tabs had to be inverted and moved to properly secure the light to the ring.
SO! Everything bad. Nothing good. Bought a Narva 7" H4 Halogen upgrade kit at SuperCheap for $120ish and haven't looked back. Plenty of quality light, fits the tabs perfectly and seal like they should.
Post Posted: Fri Mar 09, 2012 7:58 pm
X2! this is what im currently running and they work very well for the price!
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri Mar 09, 2012 11:35 pm
That "horrendous" beam pattern is common with HID retrofits - you're starting with lamp optics designed for a different light source - and even if you do take the trouble to position the globes so the light source is positioned correctly, there's no way to compensate for the difference in shape and size of the source.
A properly designed HID lamp will give you the same sharp horizontal cut off and upward "throw" on the left (for RHD vehicles), that you see with halogen lamps, just whiter & brighter.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sat Mar 10, 2012 9:01 am
I had them on my Sierra with HIDs and was very happy with them.
here they are with one installed.
glory shot
With a name like neolight how could I say no.?
Users browsing this forum: Google [Bot] and 56 guests
