| Author |
Message |
wolf_rt
Joined: Mon Jan 23, 2012 7:56 am Posts: 235 Location: Toowoomba, QLD
 Posted: Sat Mar 03, 2012 9:02 am |
just get another one for the rear...lol
There would definitely be a difference in your turning circle under power, even if you cant feel it? which seems pretty strange i must say.
I have always left the front off until needed so you can give it a bootfull and not have the car do unexpected things or break....
masterA
Joined: Tue Jan 18, 2011 3:24 am Posts: 976 Location: Perth
 Posted: Sat Mar 03, 2012 3:52 pm |
DarkHorse wrote: This thread makes no sense...  I think what MrRocky was trying to say is that without Power Steering you would be better to put a lockrite up front instead of an ARB air locker ($300 VS $1300)
_________________ Fast,Cheap,Reliable-Pick 2 & 3rd is laughable
wolf_rt
 Posted: Sat Mar 03, 2012 5:49 pm |
which is what makes no sense... ok im surprised that MrRocky doesnt find the steering lighter/better unlocked (could it just be the terrain? ie very loose dirt gravel?) but surely the main (other than steering) point of having a front locker is to save the CV's?
and since MrRocky cant feel the difference locked or unlocked... perhaps we should all be running welded front centres...
i dont see how power steer is going to make the locker better over a lockrite either?
alien
 Posted: Sat Mar 03, 2012 6:31 pm |
i thought the point of unlocking the front was to stop it understeering, as well as lightening the feel and the load on CVs
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Sat Mar 03, 2012 7:02 pm |
alien wrote: i thought the point of unlocking the front was to stop it understeering, as well as lightening the feel and the load on CVs it is they are just like your standard open diff unlocked
gregdixon
Joined: Sun Dec 28, 2008 10:30 pm Posts: 1017 Location: Perth
Vehicle: 2004 SQ625 GV
 Posted: Sat Mar 03, 2012 8:44 pm |
The whole thing is that the air lockers don't always unlock/lock when you want them too, I have seen this a few times, which is the main the reason you buy a $1600 locker.
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Sat Mar 03, 2012 8:57 pm |
gregdixon wrote: The whole thing is that the air lockers don't always unlock/lock when you want them too, I have seen this a few times, which is the main the reason you buy a $1600 locker. x2
_________________ Made in JP. Built in WA.
ajsr
 Posted: Sat Mar 03, 2012 8:58 pm |
gregdixon wrote: The whole thing is that the air lockers don't always unlock/lock when you want them too, I have seen this a few times, which is the main the reason you buy a $1600 locker. Ive only ever seen them stay engaged while under high load or wound up from a turn. straighten up and back off and out they come
Red89
 Posted: Sat Mar 03, 2012 9:14 pm |
ajsr wrote: gregdixon wrote: The whole thing is that the air lockers don't always unlock/lock when you want them too, I have seen this a few times, which is the main the reason you buy a $1600 locker. Ive only ever seen them stay engaged while under high load or wound up from a turn. straighten up and back off and out they come Bit hard to do if you are half way through a turn and need to keep turning, or in a situation where reversing up isnt feasible.
DarkHorse
 Posted: Sat Mar 03, 2012 9:19 pm |
gregdixon wrote: The whole thing is that the air lockers don't always unlock/lock when you want them too, I have seen this a few times, which is the main the reason you buy a $1600 locker. They're more controllable than an auto locker though...
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Sat Mar 03, 2012 10:03 pm |
ajsr wrote: gregdixon wrote: The whole thing is that the air lockers don't always unlock/lock when you want them too, I have seen this a few times, which is the main the reason you buy a $1600 locker. Ive only ever seen them stay engaged while under high load or wound up from a turn. straighten up and back off and out they come Maybe the new ARB design is more prone to "sticking" locked?
ajsr
 Posted: Sat Mar 03, 2012 10:17 pm |
sideways wrote: ajsr wrote: gregdixon wrote: The whole thing is that the air lockers don't always unlock/lock when you want them too, I have seen this a few times, which is the main the reason you buy a $1600 locker. Ive only ever seen them stay engaged while under high load or wound up from a turn. straighten up and back off and out they come Maybe the new ARB design is more prone to "sticking" locked? I wouldn't know mine are old, I bought them 2nd hand. regardless they still shit on an auto or welded, even if they dont always turn off exactly when you'd like
TryHard
Joined: Thu May 13, 2010 1:49 am Posts: 1041 Location: Perth
 Posted: Sun Mar 04, 2012 12:59 am |
MrRocky wrote: *sigh*
ok i was twin locked with 6:5's and lockrights on 31" tyres steering offroad was a bitch so i thought i'd get an airlocker that way i could unlock the front at the flick of a switch and enjoy normal steering after a few offroad runs in this configuration i have found the difference marginal even when off it has become apparent that a much better setup would be to use the airlocker in the rear so i can enjoy the peacefulness of a standard rear onroad and have it locked offroad returning the front to an auto locker with the addition of power steering thus addressing my original issue of improving the steering offroad and drawing the conclusion that there is no real advantage of an airlocker over an open center or lockright in relation to steering when offroad because sierra steering is gay and only able to be improved via powersteering im really on this one with you Everyone was like Get Air locker there better extra but as u found out id be more inclined to have spend money on rear air and P/s Front with Auto But thats just mean more then one way to skin a Rabbit and all do the same thing at end of day iv found anyways but im always on a budget atm
canberramav
Joined: Mon Jun 01, 2009 11:30 pm Posts: 643 Location: Canberra
 Posted: Sun Mar 04, 2012 7:02 am |
Get power steering if your struggling but it sounds as if you need to learn how to get the front to disengage. With it disingaged it should be as easy as having no locker at all.
A selectable locker in the front is ideal. 99% of comp trucks will have this setup as it is proven to be the best. In the rear not so important.
Try bouncing lightly on the accelerator while straightening the wheels up a bit to disengage. Have a play around until you figure it out. If its still not unlocking maybe you have issues somewhere with it?
Dont bother putting it in the rear. A lockright in the front is never going to be better.
Gwagensteve
 Posted: Sun Mar 04, 2012 7:51 am |
^ Wot that guy said.
I normally find letting go of the steering wheel momentarily releases the locker.
I have never had a problem with an air locker not engaging though (unless there is another problem)
Red89
 Posted: Sun Mar 04, 2012 3:12 pm |
canberramav wrote: A selectable locker in the front is ideal. 99% of comp trucks will have this setup as it is proven to be the best. In the rear not so important. Most of the comp trucks over here use full carrier autolockers like the Detroits and Grizzlies, the 2 TT entrants are both running Eaton E-lockers, largely due to sponsorship, but both previously ran Detroits front and rear.
canberramav
 Posted: Sun Mar 04, 2012 4:31 pm |
Red89 wrote: canberramav wrote: A selectable locker in the front is ideal. 99% of comp trucks will have this setup as it is proven to be the best. In the rear not so important. Most of the comp trucks over here use full carrier autolockers like the Detroits and Grizzlies, the 2 TT entrants are both running Eaton E-lockers, largely due to sponsorship, but both previously ran Detroits front and rear. Fair enough. You speak for the minority.
