It is currently Wed Oct 28, 2026 4:35 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Post Posted: Mon Mar 05, 2012 6:43 pm
Yes and as I have also mentioned earlier Jordan, I am well aware of this!
My point is I want to be in a bit of control when I offroad and I am getting very annoyed when the ESP starts overriding my actions...
All I'm saying is is there a way to disable it during 4WD situations?
I don't really have a problem with the strange braking that happens when I'm on the beach, it's the cutting power when I need it that really shits me off!
If i want to go 4H on a good beach....I would like to do it!!!!!!!
Post Posted: Mon Mar 05, 2012 7:17 pm
It must sense speed somehow.
Maybe tricking the sensor to lift the spped at which it turns on?'
I not got enough electronics knowledge to answer details.
Vehicle: 2004 SQ625 GV
Post Posted: Mon Mar 05, 2012 8:00 pm
My Pajero is the same, any sign of the wheels not doing the same speed it starts braking the slipping wheel and you loose power. Not handy when trying to get a 2tonne+ car up a dune. To correct his I just pulled the brake light fuse. If I owned it I would wire in a switch so I could turn it off. Some people grow up driving older cars on gravel roads and know how to handle them, ESP has its place but you should still have the choice to turn it off.
Post Posted: Mon Mar 05, 2012 9:00 pm
forbee4 wrote:
stockman wrote:
I had a car with it (ESP) and never again. :)
Whilst I can imagine that ESP is frustrating on the beach, It is going to be increasingly difficult to override these systems.
However, the more cars that run ESP, the better it will become. Well tuned ESP should be barely noticeable. It's often not at the moment.
As ABS technology continues to improve, so the speed and effectiveness of traction control and ESP improve. I've had the traction/ESP light fire on my current car a couple eof times but I haven't had any idea what it was "fixing" - in that I couldn't detect the intervention.
Interestingly, my current road car has two ESP settings - "on" and "traction enhanced" which loosens ESP allowing some wheelslip.
I haven't tried to feel the difference between the modes.
I would try pulling the ABS fuse and then, If that's effective, investigate a switch. I do think sand might be the worst case scenario for ESP.
Well said Steve.
There are some really good VSC systems out now and also some really bad ones that have had a go at putting me into the trees.
the quickest way to kill TRC or VSC systems when not wanted is eather the fuse like guys have mentioned or the way I do it at work and that is to unplug the loom to the braking system or related systems. This will of course make many pretty lights on the dash. But almost all of the vehicles I have done will reset the next time the vehicle does a system check. Then back to normal for the drive home with the family.
VSC is a great life saving feature when tuned correctly and used in it's operating range. (Not drifting)
4X4 For Work And Play!
Post Posted: Tue Mar 06, 2012 7:17 pm
Plum wrote:
Well said Steve.
How is this done Plum....do tell :P
Post Posted: Tue Mar 06, 2012 9:40 pm
Every vehicle is different so i cn't say how it's done. The hardest part about this one it that its speed related, so killing the entire system is the only way i know of.
The brake actuator (that applies the brakes for VSC) will have a wire harness that could be unpluged, or the ABS module. I have pulled realays out also. Depends whatever is easiest to get to when out in the bush. Trial and error with most models, sorry i haven't done any G/V.
One that is even harder of topic is speed sensitive suspension. So when in deep mud everyone puts there adjustable suspension to high mode. But when you give it shit to get through the mud its easy to hit the max speed for the high setting, so the vehicle will drop it down to normal height thinking you are on a road and at risk of a roll over. Not the best for mud.
It's all for safety for those that cn't drive.
Users browsing this forum: Google [Bot] and 323 guests
