It is currently Tue Oct 20, 2026 11:24 am
Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Wed May 09, 2012 6:41 pm
Rusho wrote:
Hopefully you didn't pay too much for the piles of crap. Cut your loses and start again 8)
That's a bit harsh! They'll make good paper weights and door stops.....
Post Posted: Wed May 09, 2012 6:47 pm
What makes them crap?
Post Posted: Wed May 09, 2012 6:48 pm
:rofl: :rofl:
Post Posted: Wed May 09, 2012 6:53 pm
x2
Post Posted: Wed May 09, 2012 6:55 pm
Bruce wrote:
x2
Like the wife's gonna let me spend another $200 passh... You all live in a fantasy world :)
Post Posted: Wed May 09, 2012 6:58 pm
Its not a complete kit. Its a home made attempt at a body lift, and a poor one at that. For under $300 there are plenty of options for a decent body lift kit. For that money you get instructions, all new blocks, high tensile bolts, washers etc.
A body lift kit still has to hold the body to the chassis. You think its a good idea to cheap out on incomplete home made junk? :?
Just Cruising sells a Kit, and so will TSOR as of next week. Thats 2 options on AZ alone! Ebay has a few more, and I believe you can get decent ones from yanky land too.
Post Posted: Wed May 09, 2012 7:02 pm
swifty_ano wrote:
Bruce wrote:
x2
:shocked: :shocked: Ask for your money back, he robbed you blind :evil:
Post Posted: Wed May 09, 2012 7:03 pm
Rusho wrote:
swifty_ano wrote:
Bruce wrote:
x2
My bad. I meant $200 ontop of what I paid.
Post Posted: Wed May 09, 2012 7:05 pm
swifty_ano wrote:
Rusho wrote:
swifty_ano wrote:
Bruce wrote:
x2
What did you pay?
Post Posted: Wed May 09, 2012 7:07 pm
Obviously too much. Half that :(
Post Posted: Wed May 09, 2012 7:08 pm
And all you got was 8 lousy chunks of aluminium? :shocked:
Post Posted: Wed May 09, 2012 7:09 pm
Correct Peter.
Really don't put that crap in.
Either save a few weeks and get a kit with full instructions from Just_Cruizin or from TSOR.
Just_Cruizin's kits I know come with FULL Step by step instructions as I'm sure TSOR will do when they come online.
Post Posted: Wed May 09, 2012 7:10 pm
Poly
Post Posted: Wed May 09, 2012 7:14 pm
Poly
Fuck man you got hosed!!!!
Fuck knows what grade they are! They have no crush tubes, and they have been hacksawed to fit. Could be fucken boat rollers for all we know.
Go knock on his door and ask for your money back mate. You paid 20x their worth, and ended up with anything BUT a body lift. :cry:
Post Posted: Wed May 09, 2012 7:18 pm
Poly
This is what happens when kids have money.
It's too late now :(
Post Posted: Wed May 09, 2012 8:49 pm
Settle down you lot, how tall are the blocks? 1" fits on a vit with stock studs cause they are heaps long
you would probably fit longer on too if you removed some of the rubber mounts, but then it would reduce the lift size anyway
Post Posted: Thu May 10, 2012 12:10 am
Doesn't matter though. No crush tubes makes poly illegal. He was given a massive Bumsteer on this one. :(
Post Posted: Thu May 10, 2012 5:18 am
It's all a learning curve to me..... Don't trust people haha this is a lesson to all tight ass apprentices...don't cheap out.
Hopefully I could get some money back on the blocks. Hopefully TSOR can keep a kit aside for me till I can afford it.
And help me fit it :peaceout:
I dont think i read In the links Royce anythint about crush tubes. Does it?
Post Posted: Thu May 10, 2012 5:40 am
Look like yours might fit a hilux
Your rims flipped from $50
Post Posted: Thu May 10, 2012 5:47 am
just slap it in as a 25mm body lift. i have a 25mm body lift on my sierra and run 33s.
Post Posted: Thu May 10, 2012 6:33 am
Now ive looked around at the 2 available bits of info from QLD DOT about this and I see nothing about crush tubes
Given its inspected once fitted how would the inspector know and how would you prove it?
whats a crush tube going to do? crush tube implies that material around it isnt able to support the weight and needs to be supported to stop it collapsing, so infact poly blocks are useless and the crush tube is doing all the work?
Post Posted: Thu May 10, 2012 10:37 am
The crush tube is a safety net. Given that under the right conditions, poly COULD ( not WILL!! ) crack, the crush tube would be there to stop the body sinking.
If you do regular checks of your vehicle, you would spot this before it became a problem.
Personally, I wouldn't buy poly blocks without them.
As for the legal side of things, maybe Greg or Bruce could provide some info.
Vehicle: 95 sierra 1.3L / 95 GTI Sierra
Post Posted: Thu May 10, 2012 1:39 pm
Just finished installing my 2" body lift I got from just_cruizin the other day, the instructions were great! But didn't realize it had to be blue plated, I guess pretty much everything does though these days, will look into getting it done when I get my seats done as well (guess a roll bar as to be as well?). How much does it usually cost?
I ran into a few problems with the transfer case and gearbox not wanting to go into gear. Ended up replacing the gearbox mount as it was totally fucked, that fixed that, and had to cut a notch into the body to get it into low range. Really not too happy about that and I don't understand why some people don't have issues and others would.
The other big issue I had is that one of the body mount bolts snapped off when tightening, seriously I swear I didn't over tighten it! Was only about half tight and just went loose and came out..... still haven't figured out how to fix that yet, thinking I either need to weld a new thread to the body or get another female bolt with a longer thread as there is still a fair bit of the original left
Any advice would be great
Post Posted: Thu May 10, 2012 1:55 pm
Holy fuck QLD transport reducing regulations?
Is it the end of the world? Am i dreaming?
Post Posted: Thu May 10, 2012 4:21 pm
We all know a sierra can run around sans a mount with no dramas, given the surface area of a cruch tube (what 1.5mm thick, 12mm dia) it would jsut punch through the floor in any circumstance that saw a block fail
Vehicle: SJ80
Post Posted: Thu May 10, 2012 5:12 pm
I would have thought it's actually just a bushing to stop the hole through the poly flogging out from the bolt through the centre.
Post Posted: Thu May 10, 2012 5:33 pm
I agree completely. And common sense tells me I am right too. But that doesn't mean the law agrees :wink:
I've only ever used/ sold alloy blocks, so I've never concerned myself with the ins and outs of poly.
I still remember Kymbo's boat roller body lift in Gumnut :lol:
Post Posted: Thu May 10, 2012 6:05 pm
We have tested the material used in the blocks that I make for Just_Cruizin.
The size was 200mm x 200mm x25mm thick. It was put under a 200 ton press for 24 hours in Sydney. Other than deflection while under load it all worked. Once the pressure was taken off the poly went back to it's original shape.
We have sold the same material used in these blocks to cranes uses to use as their levels for their feet after there was a bad bad bad accident using another material.
Don't understimate poly people. JMO
I personally would not use Ally blocks not because I sell poly but for the reasons of electrolicious of Ally "V" steel. But that's just my option.
I aggree with Peter about, "If you do regular checks of your vehicle, you would spot ANYTHING before it became a problem."
Post Posted: Thu May 10, 2012 6:42 pm
I don't want to start this discussion but :roll: I used ally on my BL and applied a very liberal coating of body deadner to either end. After 2 1/2 years I haven't noticed a darn thing wrong with them as far as electrolosis goes. It is a simple case of insulation to fix the problem.
JMO though. I am a coily drie after all pompoms pompoms
Post Posted: Thu May 10, 2012 6:43 pm
Not all do that Rusho :wink: All good mate :thefinger:
Users browsing this forum: No registered users and 399 guests
