It is currently Thu Jul 30, 2026 6:45 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2
Post Posted: Thu Aug 15, 2013 6:44 pm
Theres more than one guy who can make housings.
Make it full float, custom housing, custom axles.
Post Posted: Thu Aug 15, 2013 7:05 pm
If athol lets me then it will be full floating
housing is easy bit its the axels that are hard to find
Post Posted: Thu Aug 15, 2013 7:29 pm
but easy to order....
Post Posted: Thu Aug 15, 2013 7:32 pm
What that guy said ^
Post Posted: Thu Aug 15, 2013 7:49 pm
300M like urs would be cool
my calmini axels have been good
But i doubt they will stand up to 33and a j20
The auto should help
Post Posted: Thu Aug 15, 2013 7:55 pm
Dan how long is ur rear shaft going to be
any one know wat the length of a swb sierra shaft is
Post Posted: Thu Aug 15, 2013 8:07 pm
Stock length. I can measure tomorrow if noone else posts up a length.
Post Posted: Thu Aug 15, 2013 8:17 pm
So the auto and vit tc is around the length of a jack shaft
Post Posted: Thu Aug 15, 2013 8:20 pm
Adds about 50mm of length or something
Post Posted: Fri Aug 16, 2013 6:06 am
As Joe said, we both use them a lot, I find Vit low 2wd is great for following land barges, pootrols, rolluxs and range oilers, on steep good traction tracks. With the air shift its also easier to pop it into low while idling around camp so as not to run over dogs and small people. In high range it's pretty much stranded vitara as the Vit speedo reads accurate. Low, low is one of the best things I've ever done to the car! I've got engine braking on stupid steep stuff and even find myself throttling on down hills at times, then at the bottom of the hill you pop the air shift and its a more fuel conserving 1L low range. And well we all know what low gears do for going up hills and over rocks. With the auto and the air shift it really is a a point and shoot drive now and that's good, I work to hard to be all week to be bothered doing it when I go 4wding. Now Joe how can we make the hubs and 1L TC air shift? :)
Worth every cent and every hour spent on it.
My front diff is about 1 inch forward.
Post Posted: Fri Aug 16, 2013 6:35 am
Ken you wouldn't know how long is ur rear shaft is and how much of a angle it is on at full droop
Post Posted: Fri Aug 16, 2013 7:03 am
You can us a wt long side axle and a lj80 stockman axle and you end up with the right width and offset
Post Posted: Fri Aug 16, 2013 7:09 am
Is that a vit width or wt width
Post Posted: Fri Aug 16, 2013 8:18 am
vit width
Post Posted: Fri Aug 16, 2013 8:19 am
i was looking into the ins and outs of building a couple of rear vitara diffs for just that purpose. i.e putting a sierra case in a vit
Vehicle: Daisy
Post Posted: Fri Aug 16, 2013 10:46 am
If you want to see the difference there is some pictures in my build thread where I've laid a vit transfer and box beside the vit box and shortened jack shaft which suits an unmodified sierra tcase position.
I was trying to work out how to do twins without moving the sierra case back, I still think it's doable I should dig up the thread I found where a bloke overseas had done it.
Post Posted: Mon Aug 19, 2013 2:42 pm
Post Posted: Wed Aug 21, 2013 1:28 am
My doubler keeps the SJ tbox in the stock position, I used to have it fitted using the original frame mounts but it was a nightmare to remove and refit with the one piece guard/mount.
I run 33s with stock 3.73 samurai diffs and a 5 speed manual gearbox. I used to run it with a 4.16 SJ tbox but found that I never really shifted the doubler into low so have now swapped back to a standard 410 tbox, I think it's geared pretty much spot on for the offroading I do now. I think with 37s, auto, a doubler and 4.16 tbox it would be geared pretty well if used with lower ratio diffs.
my old ratios with the 4.16 tbox were
hi-hi 1.580:1
lo-hi 2.8756:1
hi-lo 4.16:1
lo-lo 7.571:1
The ratios with a 410 tbox are
hi-hi 1.580:1
lo-hi 2.8756:1
hi-lo 2.511:1
lo-lo 4.57:1
As for prop shafts my transmisson is mounted 50mm higher than stock and I run YJ springs so I have a bit of a wheelbase stretch both front and rear. On the front I just run a standard 410 prop as they are around 25mm longer than samurai props then on the rear I run a stock 410 rear prop (again around 25mm longer) with a 25mm spacer because I have also re-drilled the spring perches and plates back an extra 25mm.
Vehicle: Daisy
Post Posted: Wed Aug 21, 2013 6:30 am
That's what I was on about, I knew there was at least a couple of them around!
Post Posted: Wed Aug 21, 2013 8:22 am
This is one i bought off a mate. He never got to install it in his vit
i think he got it from a guy in qld
any one seen it before
Post Posted: Wed Aug 21, 2013 8:26 am
YEP, I think it used to belong to Antt. he had an orange LWB vitara
Post Posted: Wed Aug 21, 2013 8:57 am
Did u ever see them run
did it work ok
Post Posted: Wed Aug 21, 2013 8:59 am
Mine looks heaps longer then the others
how r u guys shifting the vit case
Post Posted: Wed Aug 21, 2013 9:07 am
http://auszookers.com/forum/viewtopic.php?f=5&t=1799
http://nbs4x4club.com/forum/index.php?topic=1010.110;
yeah saw it at tough tracks 1 year. was a nice setup.
Post Posted: Wed Aug 21, 2013 6:20 pm
Here's Richards write up, this is the guy that made mine http://forum.difflock.com/viewtopic.php?t=23752
Here's my shifter set up, it's not the prettiest but has been working perfectly for the last year.
Post Posted: Sun Aug 25, 2013 2:51 pm
This is as close as I can get to full droop on jack stands, there's not much more left in it though, any more will be up travel on the other side.
Post Posted: Sun Aug 25, 2013 3:21 pm
And this is it at rest. And it's 400mm flange to flange in this photo.
Users browsing this forum: No registered users and 218 guests
