shandy92 wrote:
Atari- any comments?
reckon you'd be hard pressed to find a more reliable vitara with the amount of regular wheeling it does... apart from the maintenance stuff & the fresh engine, from memory you've had very little in the way of breakages over the years.
i'd throw in the diff drops for sure & look into skid plates... my CV's are almost flat at ride height.
if you're chasing chassis clearance, you've got 2 options, larger tyres or more lift, both are going to put essentially the same stresses on essentially the same parts & you've just bought tyres & anything larger than 31's on a Vitara makes dailying it a chore & you already have the spring spacers & the other bits... see where i'm going with this.
just bung it in FFS.
