It is currently Tue Jul 28, 2026 12:03 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Poll: keep it the way it is or risk the extra capability
Dont change it 69%  69%  [ 11 ]
Fit the extra bits 31%  31%  [ 5 ]
Total votes : 16
Post Posted: Wed Oct 09, 2013 11:55 pm
got_bar_work wrote:
got_bar_work wrote:
Fwh adaptors
brass bush for back of hub
cv adaptors
not much just need someone with lathe and mill
if some one did a plan it could be knocked out on a cnc pretty easy
If someone brings me their Vit and all the parts I should be able to put it all together. Can't be that hard :lol:
I can put my diff in my half cut chassis and bring it up if u want
We also need arms that push the wheel ouit and forward a inch to make room for the cv adaptors sv and gv will not need them
If he doesn't I might in a couple of months - from FatZooks R&D they will fit the SV without widening.
Post Posted: Thu Oct 10, 2013 6:31 am
I think that tyres and a heavy right foot have a lot to do with busting CVs. A lot of people fit the most aggressive, grippy tyres that they can find and they put a lot of extra stress on the drivetrain, add a heavy right foot and you break stuff. I favour a tall tyre for ground clearance and a narrow tyre for reliability, currently I run 33 x9.5 BFG MTs with no reliability issues but I do have 5:83 R&Ps so the taller tyre doesn't kill the torque too badly.
Post Posted: Thu Oct 10, 2013 6:57 am
Wish we could get the 5:8's easily here.
Post Posted: Thu Oct 10, 2013 7:26 am
Where did u get the 5.8 from
Post Posted: Thu Oct 10, 2013 7:31 am
Calmini - sometime around 2004, they were some of the last available.
Post Posted: Fri Oct 11, 2013 11:58 am
i have run the calmini kit for about 2 years i havent broken a cv yet touch wood. i run 235 75s and rear locker but i drive carefully cause i still have a glass front diff
Post Posted: Fri Oct 11, 2013 7:38 pm
shandy92 wrote:
Atari- any comments?
reckon you'd be hard pressed to find a more reliable vitara with the amount of regular wheeling it does... apart from the maintenance stuff & the fresh engine, from memory you've had very little in the way of breakages over the years.
i'd throw in the diff drops for sure & look into skid plates... my CV's are almost flat at ride height. 8)
if you're chasing chassis clearance, you've got 2 options, larger tyres or more lift, both are going to put essentially the same stresses on essentially the same parts & you've just bought tyres & anything larger than 31's on a Vitara makes dailying it a chore & you already have the spring spacers & the other bits... see where i'm going with this. :D
just bung it in FFS. :peaceout:
Post Posted: Fri Oct 11, 2013 7:52 pm
Atari- Thanks for the comment, Yeah i havent had to many major issues over the years so the vit has been good to me. Do you recon it would matter if you dont fit a dropped pinion mount?
That is true and yeah I see where your going :)
Thanks for the input, banga and rhinoman
Users browsing this forum: No registered users and 348 guests
