It is currently Sat Nov 14, 2026 9:01 pm
Post Posted: Wed Apr 21, 2010 11:07 pm
I am in the process of replacing my wheel bearings and all the seals including the inner hub seals. (Suz part# 09289-48004).
Has anyone ever tries this ?? am I putting the thing on the wrong way, caus I have already stuffed one of them and I can't get the shits on ???
does the rubber go into the hub or does the metal go over the outside - if the later, why are they loose ?
Thanks
Post Posted: Wed Apr 21, 2010 11:13 pm
If you look on the DIY section there is a complete brake down on how to do this with pictures
Post Posted: Wed Apr 21, 2010 11:15 pm
ummmm well I was going topost the link for you but I cant find the DIY section.... ummmm ask royce or steve to give you a link to the hub rebuild thread.....
Post Posted: Wed Apr 21, 2010 11:17 pm
Ok - I'm not going mad then .. Can't find it either ? - Anyone got any links???
Vehicle: LJ50V, SJ70
Post Posted: Thu Apr 22, 2010 5:33 am
Thanks
As the Actress said to the Choirboy, are you sure you've got the right hole?
09289-48004 does not fit in the hub itself, and the part number says its a 48mm seal. The inner seal on the hub is 09283-54001, a 54mm seal, which would explain why your seal is a loose fit (BTW, you would have saved a lot of head scratching and searching if you'd have said VITARA hub!):
Users browsing this forum: No registered users and 75 guests
