It is currently Sat Nov 14, 2026 6:52 pm
Post Posted: Thu Apr 22, 2010 12:48 am
hey guys
whats the cheapest way to get enough lift out of my coily to fit a set of 30's on it? i saw 40mm springs on the suzisport site for $400. any other ideas?
and no, selling it to buy a leafy isn't an option
Post Posted: Thu Apr 22, 2010 12:53 am
ebay ultima lift...$650 ish 2 inch springs, shocks and struts. If you make it to bribie saturday you can have a look at my POS
Post Posted: Thu Apr 22, 2010 12:57 am
guessing those 30mm spaces are a waste of time?
Post Posted: Thu Apr 22, 2010 12:58 am
I would say yes, others may disagree. You could do body lift for around $200
Post Posted: Thu Apr 22, 2010 1:01 am
whats involved with the body lift on a coily?
Post Posted: Thu Apr 22, 2010 1:07 am
Buy it and fit it :P Again...i will show ya saturday. Mostly a time consuming exercise more than anything
Post Posted: Thu Apr 22, 2010 1:14 am
:P Look at the coily love!!! :P
I'd go spring lift before you lift the body, body lift won't give you any more travel.
Post Posted: Thu Apr 22, 2010 1:18 am
:thefinger: :thefinger: There is not many of us, we need to stick together peaceout
Post Posted: Thu Apr 22, 2010 1:23 am
I'm just a lil concerned what you use for glue tho. :shocked:
Post Posted: Thu Apr 22, 2010 1:25 am
You know..have you you run out? I can whip you up another batch :wink:
Post Posted: Thu Apr 22, 2010 1:40 am
oh yeah i'd be going the suspension lift before the body lift, just curious about the body lift
Post Posted: Thu Apr 22, 2010 1:44 am
and a suspension lift will give you no extra room for larger tyres.
I'd go bodylift first.
Post Posted: Thu Apr 22, 2010 2:02 am
Each to their own, I'd rather be able to get the tyre's to the ground than clearing the gaurd's.
Post Posted: Thu Apr 22, 2010 2:05 am
mmm maybe i'll just go exhaust and wait till i have cash for both body and sus lift
Post Posted: Thu Apr 22, 2010 4:08 am
a good suspension lift will actually give you less tyre clearance as it should compress more, but you have the right idea by doing both at the same time.
Post Posted: Thu Apr 22, 2010 4:31 am
Isn't that the whole idea of a bump stop? I wouldn't say it'd give you less clearance
helloo
Post Posted: Thu Apr 22, 2010 4:37 pm
coil spacers will not fit on the standard front sturts, they are to short.
Post Posted: Thu Apr 22, 2010 9:08 pm
Well I kinda made my own kit out of anything that will fit, and it
works will. Gives me just over 45mm of lift and awesome flex. :wink:
Post Posted: Fri Apr 23, 2010 12:02 am
if the opposite site is allowed to extend further due to the new suspension the pivot point, bump stop is the same, hence the compression side goes up further into the wheel arch. This assumes that the old suspension would allow the diff to hit the bumpstop, most don't until the sag.
Users browsing this forum: No registered users and 67 guests
