Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Bundyrumandcoke
 Posted: Fri Jun 29, 2007 10:58 pm |
The LJ80 I am doing up has a F10A fitted to it. The sump sits directly over the front diff, and has been punched up. Another sump came with the purchase, so I want to know if the sump can be reversed for clearance, and the pickup modified to suit? And are there any other issues with this mod?
Bundy
royce
 Posted: Fri Jun 29, 2007 11:21 pm |
you need to get a sump and pickup from an 800cc LJ engine, that will clear properly
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Fri Jun 29, 2007 11:33 pm |
bash it up some more so it clears the diff, no problem
Kymb0
 Posted: Fri Jun 29, 2007 11:47 pm |
I had a similar problem with the motor I was putting into the LJ I am building. The big dip in the sump for the 4wd oil reservoir was directly over the diff pumkin so we cut the sump an inch from the flange and spun it around. We also had to cut and change the pickup.
Turned out to be a work of art.
Bundyrumandcoke
 Posted: Sat Jun 30, 2007 2:36 pm |
So the F8A and the F10A are the same basic block configuration? As in sump holes, size of the sump mating surface, ect.
royce
 Posted: Sat Jun 30, 2007 2:45 pm |
I havent done it but asked somebody that has and he said yep bolts straight on
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 539 guests
