It is currently Mon Nov 02, 2026 11:02 am
Post Posted: Fri Jun 29, 2007 10:58 pm
The LJ80 I am doing up has a F10A fitted to it. The sump sits directly over the front diff, and has been punched up. Another sump came with the purchase, so I want to know if the sump can be reversed for clearance, and the pickup modified to suit? And are there any other issues with this mod?
Bundy
Post Posted: Fri Jun 29, 2007 11:21 pm
you need to get a sump and pickup from an 800cc LJ engine, that will clear properly
Vehicle: 75 Cruiser
Post Posted: Fri Jun 29, 2007 11:33 pm
bash it up some more so it clears the diff, no problem :)
Post Posted: Fri Jun 29, 2007 11:47 pm
I had a similar problem with the motor I was putting into the LJ I am building. The big dip in the sump for the 4wd oil reservoir was directly over the diff pumkin so we cut the sump an inch from the flange and spun it around. We also had to cut and change the pickup.
Turned out to be a work of art.
Post Posted: Sat Jun 30, 2007 2:36 pm
So the F8A and the F10A are the same basic block configuration? As in sump holes, size of the sump mating surface, ect.
Post Posted: Sat Jun 30, 2007 2:45 pm
I havent done it but asked somebody that has and he said yep bolts straight on
Users browsing this forum: No registered users and 81 guests
