| Author |
Message |
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Sun Jul 18, 2010 10:03 am |
what is this censer for? its on the manifold that was on the old engine but not on the import. can i leave the connection off on not get a fault?
nissvit
Joined: Sun Apr 06, 2008 11:30 pm Posts: 184 Location: Brisbane
 Posted: Sun Jul 18, 2010 10:07 am |
what year engine is this off?
if its a really late engine, i think it is where the idle air control valve is located..
but the photo is pretty hard to see..
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Sun Jul 18, 2010 10:12 am |
nissvit wrote: what year engine is this off? if its a really late engine, i think it is where the idle air control valve is located..
I'm with the eye's..
_________________ I used to be indecisive,
Brett
 Posted: Sun Jul 18, 2010 10:50 am |
the manifold is off a 95. the dizzy has the 4 wire connection. the import has the 2 wire dizzy
i'm pointing at the bit under the pipe.
if its the aic will the engine run with out it on import engine that never had it?
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Sun Jul 18, 2010 10:54 am |
Brett
 Posted: Sun Jul 18, 2010 11:08 am |
sorry i can't read or write that well, looks good to me
buzbox
 Posted: Sun Jul 18, 2010 11:18 am |
Sensor
I is speaching proppa england peaceout
I think it's the Idle speed controller.
BTW happy 1001 posts
steak_knife
 Posted: Sun Jul 18, 2010 11:19 am |
Brett wrote: the manifold is off a 95. the dizzy has the 4 wire connection. the import has the 2 wire dizzy
You'll need some thing to control idle, It's just a ecu controlled air bypass, bypasses the butterfly to let more air in, more air the higher the idle goes..
But it is needed lot's..
To answer your question tho, yeas it will run, but the idle can not be controlled, unless you get out & adjust it..
royce
 Posted: Sun Jul 18, 2010 8:41 pm |
you are probably better off fitting the manifold that belongs to teh ecu you are going to use
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Sun Jul 18, 2010 9:41 pm |
royce wrote: you are probably better off fitting the manifold that belongs to teh ecu you are going to use
what he said.
_________________ builder of custom road legal zooks......and stuff.
BlueSuzy
 Posted: Mon Jul 19, 2010 3:14 am |
joeblow wrote: royce wrote: you are probably better off fitting the manifold that belongs to teh ecu you are going to use what he said.
Ditto, if you still have the ol' motor.
Brett
 Posted: Mon Jul 19, 2010 7:26 am |
didn't want to hear that. i still have the manifold (its the one in the pic) so i'll have to swap that this weekend.
on a side note the top half of the manifolds are different sizes so the dont bolt up
BlueSuzy
 Posted: Mon Jul 19, 2010 1:17 pm |
Can't be that hard unbolting it off the head..
Brett
 Posted: Mon Jul 19, 2010 6:54 pm |
out of every engine i have worked on the 16b is the hardest to work on. you need little kid hands to get to the bolts
joeblow
 Posted: Mon Jul 19, 2010 9:38 pm |
Brett wrote: out of every engine i have worked on the 16b is the hardest to work on. you need little kid hands to get to the bolts
are you serious? i'm 6'4" with big arse man hands and i still don't have any dramas working on a 16b. i think you have not worked on too many engines then.
stop being a lazy bastard and swap the manifolds over from the head.
Brett
 Posted: Tue Jul 20, 2010 8:24 am |
i have worked on a few but mostly older engines. i did think the last rover i had was hard till i got this
