It is currently Sat Oct 10, 2026 1:37 pm
Post Posted: Sun Jul 18, 2010 10:03 am
what is this censer for? its on the manifold that was on the old engine but not on the import. can i leave the connection off on not get a fault?
Post Posted: Sun Jul 18, 2010 10:07 am
what year engine is this off?
if its a really late engine, i think it is where the idle air control valve is located..
but the photo is pretty hard to see..
Post Posted: Sun Jul 18, 2010 10:12 am
I'm with the eye's.. 8O
Post Posted: Sun Jul 18, 2010 10:50 am
the manifold is off a 95. the dizzy has the 4 wire connection. the import has the 2 wire dizzy
i'm pointing at the bit under the pipe.
if its the aic will the engine run with out it on import engine that never had it?
Vehicle: LWB Sierra & XL7
Post Posted: Sun Jul 18, 2010 10:54 am
what's a cencer?
'92 Vitara & Camper trailer
Post Posted: Sun Jul 18, 2010 11:08 am
sorry i can't read or write that well, looks good to me
Post Posted: Sun Jul 18, 2010 11:18 am
Sensor :lol:
I is speaching proppa england peaceout
I think it's the Idle speed controller.
BTW happy 1001 posts
Post Posted: Sun Jul 18, 2010 11:19 am
You'll need some thing to control idle, It's just a ecu controlled air bypass, bypasses the butterfly to let more air in, more air the higher the idle goes..
But it is needed lot's..
To answer your question tho, yeas it will run, but the idle can not be controlled, unless you get out & adjust it..
Post Posted: Sun Jul 18, 2010 8:41 pm
you are probably better off fitting the manifold that belongs to teh ecu you are going to use
Post Posted: Sun Jul 18, 2010 9:41 pm
what he said.
Post Posted: Mon Jul 19, 2010 3:14 am
what he said.
Ditto, if you still have the ol' motor.
Post Posted: Mon Jul 19, 2010 7:26 am
didn't want to hear that. i still have the manifold (its the one in the pic) so i'll have to swap that this weekend.
on a side note the top half of the manifolds are different sizes so the dont bolt up :cry:
Post Posted: Mon Jul 19, 2010 1:17 pm
Can't be that hard unbolting it off the head..
Post Posted: Mon Jul 19, 2010 6:54 pm
out of every engine i have worked on the 16b is the hardest to work on. you need little kid hands to get to the bolts
Post Posted: Mon Jul 19, 2010 9:38 pm
are you serious? i'm 6'4" with big arse man hands and i still don't have any dramas working on a 16b. i think you have not worked on too many engines then.
stop being a lazy bastard and swap the manifolds over from the head.
Post Posted: Tue Jul 20, 2010 8:24 am
i have worked on a few but mostly older engines. i did think the last rover i had was hard till i got this :)
Users browsing this forum: Google [Bot] and 114 guests
