It is currently Sun Aug 02, 2026 3:25 am
Post Posted: Sun Aug 01, 2010 1:11 am
my 95 sierra over heated on friday night and blew the core on my radiator,yesterday i replaced the radiator , waterpump , fan belt, thermostat & radiator hoses i just filled it all up with coolant run it with out the cap off till got up to temp then put the cap back on i came back to check it after a couple of minutes and the guage was off the end of red zone just curious were the temp sender is or if there could be something else going wrong
Vehicle: Suzuki
Post Posted: Sun Aug 01, 2010 1:15 am
Temp sender is on the thermostat housing, Will have one wire coming off of it via spade connector.
Post Posted: Sun Aug 01, 2010 9:35 am
you want the fire & brimstone or the hippy way.
F&B. head's bent.
Hippy. you may of fitted the thermostat upside down, or it has air under it, causing it to blow the water out..
Post Posted: Sun Aug 01, 2010 10:00 am
thanks stek i pulled the thermostat out cheched it in some water on the stove in case it was a dodgy new one put it back in still done the same thing so went and got a after market temp gauge and sender all seems good so far ran it for over an hour and didnt go over 180degrees fareinheight
Post Posted: Sun Aug 01, 2010 10:06 am
you need to bleed teh thermostat, easy way is keep the revs up a bit until the thermostat gets hot enough to open
Post Posted: Sun Aug 01, 2010 10:28 am
Also help's to have the front of the car slightly uphill.
Users browsing this forum: No registered users and 431 guests
