It is currently Sun Oct 11, 2026 11:43 am
Post Posted: Tue Jan 24, 2012 1:35 pm
hey guys just wondering if i need to run reduction gears on 31 i have a 1.3l 5sp sierra
Post Posted: Tue Jan 24, 2012 1:42 pm
Yes.
Post Posted: Tue Jan 24, 2012 3:53 pm
sideways wrote:
Yes.
x2
Post Posted: Tue Jan 24, 2012 4:38 pm
What will happen if I don't ?
Post Posted: Tue Jan 24, 2012 5:02 pm
No 5th gear much
Burn out your clutch quicker
Shit hill starts
Loose top end speed on highway unless going down a hill.
It's drivable but it's best to get gears so you clutch is happy
Post Posted: Tue Jan 24, 2012 5:58 pm
zooky08 wrote:
No 5th gear much
Shit hill starts
X2... yeah the little zook really needs those gears :lol:
Post Posted: Tue Jan 24, 2012 6:02 pm
Offroad you need to flog it to get anywhere.
If you try to climb things you'll slip/burn out your clutch leaving you to sit and wait for it to cool down before you can keep driving.
Take offs on road need a slight clutch slip.
Fuel bill goes up.
Drivability goes down.
And it's just fucking frustrating. So save the hassle, and get gearing.
Post Posted: Tue Jan 24, 2012 7:00 pm
you will need spoa to :lol: :lol: i kid i kid
Vehicle: '94 suzuki maruti
Post Posted: Tue Jan 24, 2012 7:07 pm
you dont NEED it, but i guarantee that after driving it for a while on 31's, you'll realise you want them bad. it just doesnt crawl, even in low 1st.
Post Posted: Tue Jan 24, 2012 7:51 pm
The car moves without gearing but it's not worth wasting your time..
I would say you do NEED them.
Post Posted: Tue Jan 24, 2012 7:55 pm
:lol: yeah. 4" of lift cut your guards then beat them with a hammer!
:roll:
Post Posted: Tue Jan 24, 2012 8:18 pm
and you will get very good at taking off in low range 1st then shifting to high range 1st on anything steeper than 5 degree incline :P
Vehicle: '92 Sierra
Post Posted: Tue Jan 24, 2012 11:21 pm
Did one trip on Fraser with the 1.3, stock gearing and 31's. I ordered gears the day I got back.......
Post Posted: Wed Jan 25, 2012 2:30 am
What are gears worth to put in ? And what the biggest tyre I can go with out gears
Post Posted: Wed Jan 25, 2012 2:42 am
29's (235/75r15).
Gears are roughly $500 depending on what ratio you get.
Post Posted: Wed Jan 25, 2012 3:50 am
ANY increase in tyre size over stock will nett a reduction in drivability in the absence of gearing.
So where YOU draw the line in the sand may be different to someone else. And the money you don't spend on gearing straight away will be chewed up by extra fuel, clutch, and other repairs brought about by having to ride your clutch and generally ring your cars neck to get it places.
Get the gears asap.
Also worth noting that the costs don't stop mounting at what the gearset costs you. It is advisable to install a fresh set of bearings etc when fitting the gears to help keep them running as they should.
Vehicle: 93 Sierra
Post Posted: Wed Jan 25, 2012 5:55 am
235/75R15's are driveable on stock gearing, but they still suck on any kind of ascent - and descent control is crap too. They're fine on road though and can be cajoled places offroad so long as you don't mind butchering your clutch.
I drove mine around the block on 31's with stock gearing (having driven 235/75R15's for a few years with stock gearing) and parked it up in the garage until my gears arrived. It was near undriveable.
So short story - definitely swap out your Tcase gears if going to 31's, and further to Fatzook's comment re bearings, allow for fresh Tcase mounts and a Roctoy ring or similar. I broke a stock mount pretty quickly with the new gears, and the Roctoy ring (if fitted properly) will help transmit torque from the housing back into the mounts and stop you splitting your Tcase.
Post Posted: Wed Jan 25, 2012 9:55 am
Is a transfer rebuild with new bearings and crawler gears possible without a press?
If you do the roctoy ring and upgraded mounts, is the transfer case reliability still an issue with 31's on 3.7 diff gears?
Post Posted: Wed Jan 25, 2012 10:08 am
yes. my trans case was rebuilt with 6.5s and no press.
dont upgrade the mounts :wink:
Post Posted: Wed Jan 25, 2012 10:20 am
ive run 6:5's in different cars over 8 years on standard mounts and brackets
from 29's up to 34's with twin lockers and i dont exactly baby it either.
its just luck of the draw some guys do them all the time even when they upgrade
Post Posted: Wed Jan 25, 2012 10:25 am
Good to know... the gearing options are kind of screwy, when you look at replacing the 3.7's with 4.57's...
Since i was going to get dual lockers i was thinking 4.57's would be good just to take the load off the transfer, but if its a non issue i will just get some transfer gears!
Post Posted: Wed Jan 25, 2012 10:34 am
Where do you get 4.57's from? Never seen that ratio before.
Post Posted: Wed Jan 25, 2012 10:40 am
http://www.lowrangeoffroad.com/index.ph ... gears.html
Post Posted: Wed Jan 25, 2012 10:44 am
Right.
Why not just use 4.625 vitara R&P's? WAY cheaper!
Post Posted: Wed Jan 25, 2012 10:46 am
4.1's would be nice... but appear to be like rocking horse s***
3.9 don't really seem to be worth the effort.
~4.6's seem to give too many revs on the highway once transfer gears are fitted, and i don't thing they would give a good crawl ratio with std transfer gearinbg
Post Posted: Wed Jan 25, 2012 10:49 am
Yeah 4.1' are not common. You can also get 4.3's from GV's aswell.
Post Posted: Wed Jan 25, 2012 10:57 am
AHHH... 4.3 gives the good numbers with 4.16 Transfer gears!
GV is Grand Vitara I presume? what model exactly am I looking for?
that combo would give me a 65.33:1 crawl ratio, which sounds good
and ~3700 rpm highway cruise.
Post Posted: Wed Jan 25, 2012 10:59 am
Not sure. They aren't the most common ratio, but probably easier to find than sierra WT 4.11's.
Post Posted: Wed Jan 25, 2012 11:10 am
Found this on a US site... looks like it is only the 94-98 MPI 3spd autos with the 4.3's Does the US info hold for Australia?
anybody know how common this model is in Aus?
89-98 Trackick gear ratios
Years....2 or 4 door...Engine type...Transmission...Axle ratio
89 2 1.3L carb. 5 speed man. 5.625
89-95 2 1.6L TBI 5 speed man. 5.125
89-95 2 1.6L TBI 3 speed auto 4.625
91 4 1.6L TBI 5 speed man. 5.375 4dr. 2door is 5.125
91 4 1.6L TBI 3 speed auto 4.625 2 or 4dr.
91 samurai, 5sp 3.727 (refr)
92-98 4 1.6L MPFI 5 speed man. 5.125
92-98 4 1.6L MPFI 4 speed auto 5.125
94-98 2 1.6L MPFI 5 speed man. 5.125
94-98 2 1.6L MPFI 3 speed auto 4.30
94-98 2 1.6L MPFI 4 speed auto 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
96-98 4 door 1.8l 16V DOHC MPFI manual or auto 5.125
Post Posted: Wed Jan 25, 2012 7:56 pm
That model never existed in Australia - three speed auto EFI 1.6.
I'm not sure what model used 4.3's in Australia, but they would be almost impossible to find - remember you need to find two cars being wrecked to get two front diffs.
If you really want to do diff gears, just go 4.6 - much easier to find. 3986rpm @ 100 isn't ideal, but it's liveable - It's pretty much the same highway revs a stock jimmy runs.
However, throwing some 6.4 transfer gears in and leaving the diffs 3.7 is pretty good, - 3400rpm @ 100 and 84:1 crawl. You would need to change diff gears if you wanted bigger tyres though, and with, say, 33's and 4.6 diffs you are back to 3900@100 and a 107:1 crawl.
Generally, the beauty of transfer gears is they let you stay out of doing diff gears. It's pretty expensive to do a transfer and both diffs to run a 31" tyre.
Users browsing this forum: No registered users and 239 guests
