Page 1 of 1
[ 14 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Wed Oct 27, 2010 1:58 am |
Folks, I'm trying, with my limited knowledge of suzis to tune a 1.6l carby donk.
There was a very bad flat spot, got rid of that, cool as, pretty stoked, but when I took it for a tune up run, and got back, it diesels, bad.
Spoke to the owner, and that is normal.
Got some carb cleaner and run that thru it, used about half the can, took it for a run, alls well, yaaaa.
This only happened at full running temp.
Did a minor adjustment on the air/fuel mix, took her for another run, and when I turned her off, blasted diesels back.
Put in some 98, not sure of what was in it before, (owner is now in hospital) probably 91 crap, thats why I thought just a carbon deposit, and with the carb cleaner, and a 120kph run for 50k it shut down beautifully, but like I say, now its back after a 2nd run.
Ok, soooo ????
Any ideas.
_________________ Bad decisions make good stories.
matty_wall
Joined: Sun Feb 15, 2009 10:30 pm Posts: 989 Location: Blue Mountains
Vehicle: SJ51T
 Posted: Wed Oct 27, 2010 2:12 am |
i had this problem but for a while. I put a can of that subaru head cleaner through. i think it was that anyway, worked wonders for me.
Have you checked your timing? it may to to advanced. I read somewhere it can diesel because of that.
SuziBlu
 Posted: Wed Oct 27, 2010 2:22 am |
Yea got the flat spot out with a carb tune, timing, points, cap and rotor, these were shocking, leads tested fine.
In the good old days, now an then we would go out and flatten it, run her as hard as possible, especially the early V8s, but it helped all. This is a sort of sunday only to church type car, fuel is probably old as the hills, carbon build up in the head was my first guess, the cleaner did the trick first time, but after a second 120k run it was back.
royce
 Posted: Wed Oct 27, 2010 2:35 am |
Air leak, spray some of that carb cleaner around the intake gaskets and vacuum hoses, listen for a rise in revs
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Wed Oct 27, 2010 2:36 am |
does the vit carby have a fuel cut off solenoid?
also the plugs, if they are running too hot, they will cause it to diesel too.
pull the plugs out and inspect them, there was a good link posted in a thread on this about a year ago.
SuziBlu
 Posted: Wed Oct 27, 2010 4:19 am |
Plugs are fine, looks perfect.
Cut off solenoid, sorry, no idea, I hate the so very complicated asin carbs. I am only doing this for an old bloke who sadly has the big C, and its one thing after another. Poor ole bugger, spoke to me yesterday about getting it running sweet, last night he had a turn for the worst, an had an ambulance come pick him up, seems he has a few days left.
Maybe it needs an air leak test, and another clean out, with a WOT run. I can feel a 4wd sesh as WOT is a bit naughty nowdays on the open road.
I would like to get it running like silk before he goes away, so he can feel comfy knowing his wife has a car he can trust.
Air leak, mkay, will have a go, its an old car, as in, not very often used, so maybe things have dried and are now leaking.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Wed Oct 27, 2010 4:37 am |
royce wrote: Air leak, spray some of that carb cleaner around the intake gaskets and vacuum hoses, listen for a rise in revs
Carby cleaner will make the revs drop, an ether type spray will make them rise
alien
 Posted: Wed Oct 27, 2010 6:25 am |
when mine was doing that (running on) it was the fuel float level in the carby... basically the carby was a little worn and needed a refresh.
SuziBlu
 Posted: Wed Oct 27, 2010 7:06 am |
ScrawnC wrote: royce wrote: Air leak, spray some of that carb cleaner around the intake gaskets and vacuum hoses, listen for a rise in revs Carby cleaner will make the revs drop, an ether type spray will make them rise
Yea, squirt carby cleaner down the throat, an major loss of revs, even from around 5,000, a squirt makes revs drop very fast. But, I hope im right, it cleans out carbon deposits within the chamber.
Alien, taa mate, cept, no way am I gunna open up a aisin carb, I seriously think they are over complicated to the point of shear stupidity.
Dun a run, got her up to operating temp, poured some more cleaner down the throat whilst she running, lots. Took her for a run, WOT in 3rd at 4,000, foot on the brake, held her there, temp gauge rose fast, kept her there, thinking, if its a carbon deposit, your outa here.
Slow run home, turned her off, perfect. Thats not to say that tomorrow she will not diesel, as she did second run.
Gunna try her, IF she misbehaves, some "start ya barsted" and do as Royce says.
SuziBlu
 Posted: Wed Oct 27, 2010 11:22 pm |
Ole mate doesn't need his car anymore, he took off on his next adventure at 0930hrs today.
Would have liked to be able to tell him that his car is running sweet as for his wife, and to say fare well, but that didn't happen.
Life is a pretty fickle thing, 4 days ago when I picked up his car, he was looking forward to when the last lot of chemo had diminished its hold on him, and he could come with me down the sand hills and have a beer. I will take him down there in a few days and leave him there, stand on top of a dirty great big hill and pure out his ashes.
[E-Z]
Joined: Mon Oct 25, 2010 7:32 am Posts: 131 Location: sunshine coast QLD
 Posted: Wed Oct 27, 2010 11:51 pm |
BlueSuzy
 Posted: Thu Oct 28, 2010 12:30 am |
rip.
Ben_Sierra
Joined: Wed Sep 30, 2009 11:30 pm Posts: 4472 Location: Perth
 Posted: Thu Oct 28, 2010 12:36 am |
My condolences SuziBlu.
_________________ I want my old sig back
atari4x4
 Posted: Thu Oct 28, 2010 12:38 am |
David sorry to hear that you've lost a mate, at least he can now rest in peace.
Page 1 of 1
[ 14 posts ] |
Users browsing this forum: No registered users and 173 guests
