It is currently Wed Oct 28, 2026 1:57 am
Post Posted: Wed Mar 30, 2011 8:32 am
Hey everyone,
Unsure of the best way to approach fitting transfer reduction gears to my 1.0L sierra..
1.0L Long wheel base Chasis
1.3L Motor
1.3L 5 Speed
1.0L Transfer (NO SWITCH)
1.0L Tail Shafts
1.3L Wide Track Diffs (Flanges Drilled to suit)
To my knowledge Reduction gears wont fit into that transfer.
Long wheel Base Wide Track Shafts are rare as rocking horse sh!t
And need to keep the Drum Brake on transfer
What would you do?
Cheers in Advance and i know this may have been covered before and i have wasted to much time trying to find it already.
Post Posted: Wed Mar 30, 2011 8:37 am
what size tyre are you trying to gear, and what terrain do you drive?
Post Posted: Wed Mar 30, 2011 8:38 am
30's atm But ideally aiming for 32's
And rock
Post Posted: Wed Mar 30, 2011 8:41 am
my lwb rear tail shaft is a half wt half nt jobbie.
wt at the diff and nt and the transcase.
get a nt 1.3 trans case and stick gears in and away ya go.
Post Posted: Wed Mar 30, 2011 8:44 am
So wait all your saying is get a 1.3 nt Transfer and it will mate up to my 1.0L tailshafts?
1.0L Flanges and NT are the same then?
Vehicle: Daisy
As shep said, also, can't you just re-mount the case handbrake on the 1.3 case?
Post Posted: Wed Mar 30, 2011 8:49 am
thats what i did
i have wt front diff and tailshaft, wt jack shaft, wt transfercase with nt handbrake and a half and half
rear shaft and wt rear diff.
i wouldent mind betting though that the long bit of a lwb rear tailshaft is the same as
the long bit of a swb front shaft.
Post Posted: Wed Mar 30, 2011 8:50 am
NT transfers have the handbrake on them anyway
Users browsing this forum: Google [Bot] and 325 guests
