It is currently Thu Oct 08, 2026 3:01 pm
Vehicle: 95 Sierra Soft top
Post Posted: Tue Nov 30, 2010 5:13 am
Hey guys, ill keep it nice and short
First
I think i got water in my fuel tank and just wanted to know how i can remove it and whats the best way
Second
every time i brake my sierra pulls hard to the left and its wores when you brake harder its feels like the brake is stuck on well one side that is
and just before i went to wash the rims and tyres thinking it had something to do with the dirt on them and the right front disc brakes where steaming like a sorna when i sprayed them with water
so what could this be ??
Keith :wink:
Post Posted: Tue Nov 30, 2010 5:21 am
either remove & drain the tank or chuck in a cup of methylated spirits.
Post Posted: Tue Nov 30, 2010 5:44 am
If you car pulls to one side, it sounds like your caliper is frozen on. Do you get that wonderful smell of hot brakes when you drive? I had one of my calipers lock on and it damn near drove me off the road when i braked. Easy to check.
Jack up the car and remove the wheel
Undo and remove caliper
If you remove the brake master cylinder lid you should be able to push the brake pad back into the cylinder easyish.
If it is frozen on, get a bucket and put the caliper in it.
Jump in the car and push the brake pedal. The hydrolic pressure should be enough to force the cylinder out. My was really shagged and this work. Made a pretty mess but got it apart enough to put a caliper kit (new rubbers) on and remove the rust that was on the front lip of the cylinder.
Hope this helps and not just confuses :D
Post Posted: Tue Nov 30, 2010 8:13 am
Yeah i do smell the hot brakes burning lol well i think that might be the case mate cheers ill have a look at that and see what i can do
now with the fuel tank is it easy to pull of can anybody do a job like that ??
Post Posted: Tue Nov 30, 2010 11:45 am
4 bolts and a couple of hoses
i jus did mine it isnt that hard
Post Posted: Tue Nov 30, 2010 11:50 am
put metho in your tank.
Post Posted: Tue Nov 30, 2010 12:08 pm
Wait... Aren't you supposed to drink the metho? D: Well that is where I went wrong. Haha jokes.
Oh and while your tank is off you might as well pull apart the fuel gauge sensor and give it a clean. :) And use an air compressor hose to remove any dings :)
My build: Click WWW
Post Posted: Wed Dec 01, 2010 5:19 am
Can the zook run on metho ?? lol but if its an easy job i mite do it cause ive got one big ding in it lol so might fix it up while its off
But can it run metho ??
Post Posted: Wed Dec 01, 2010 5:26 am
as long as there is petrol in there too, metho shouldnt hurt it, it will mix with the water and burn it away
Post Posted: Wed Dec 01, 2010 5:58 am
Narrow track sierras have a drain bung in the bottom of the tank. Widetracks don't.
What makes you think you have water in the tank? Personally, I don't think metho will work for any volume of water - you'd have to add too much to absorb any reasonable quantity. I'd pull the tank if you have a reasonable suspicion.
Yes, you need to rebuild the RHF brake caliper.
Vehicle: '94 suzuki maruti
Post Posted: Wed Dec 01, 2010 7:42 am
its pulling to the left, but its the right one thats running hot?
Post Posted: Thu Dec 02, 2010 4:59 am
Only when i brake ?? its weird cause you would think its the left one yeah ? but then while driving, it does pull to the right
And about why i think theres water in the tank lol
Just click under here
http://s1188.photobucket.com/albums/z406/IN2DEP/
Post Posted: Thu Dec 02, 2010 5:36 am
Didn't look like the filler was under for any period of time.
Might be worth dropping the tank... but is it running OK? I'd leavewell enough alone if it's running fine.
Post Posted: Thu Dec 02, 2010 5:53 am
Yeah it was deeper but i got the back end up in the vid, but since then the car always stall when it gets 3/4 left on the gage so thats just my guess, and it never did that before the water and the sinking lol
But ill pull it off and check it out
Users browsing this forum: Google [Bot] and 183 guests
