| Author |
Message |
superduki
Joined: Thu Nov 05, 2009 10:30 pm Posts: 466 Location: Tasmania
 Posted: Thu Dec 02, 2010 8:19 am |
G'day chaps,
Quick question
Does anyone know what or how the idle is controlled on a g13bb, Mine idles high, and I'd like to bring it down. Sometimes it idles fine, other times its 1500 odd. No I don't have a vaccuum leak either.
Next question, does anyone know the tacho output on the ecu? I don't have one at the moment, And i'd like to wire it up to the sierra dash if possible.
That is all
Thanks
_________________ GTi Turbo & A LWB Sierra.
inbits
Joined: Mon Sep 13, 2010 8:30 am Posts: 600 Location: qld
 Posted: Thu Dec 02, 2010 8:21 am |
im pretty sure the g13bb ecu wont work with the sierra tacho
Brenno
Joined: Thu Apr 22, 2010 11:30 pm Posts: 1000 Location: Hobart
 Posted: Thu Dec 02, 2010 11:44 pm |
I'm glad you are getting around to fixing these problems! When I had it, it never idled that high. Have you got a Jimny service manual?
I think Spamwell hooked up his sierra with a jimny tacho input, dont know how though.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Fri Dec 03, 2010 12:08 am |
Sams Coily had an aftermarket tacho fitted.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Fri Dec 03, 2010 12:18 am |
I use a baleno one, with the baleno twin coil motor...
The g13bbs are twin coil also. So they should be similar. Tried hunting down a jim cluster?
tobeszook
Joined: Sun Sep 26, 2010 7:38 am Posts: 453 Location: Drysdale Vic
 Posted: Fri Dec 03, 2010 8:20 pm |
i don't know if this helps but my g16b started to idle high( and running a bit rough) i just gave it a full service now its back to normal
tobeszook
 Posted: Fri Dec 03, 2010 8:24 pm |
tuffcoily is parting out a jimny with a g13bb
superduki
 Posted: Wed Dec 08, 2010 9:23 am |
Hmmm, may possibly have to do some investigation myself then!
Currently it has four bent rods. Hydraulic'd it in a river on saturday,
Machine shop has bits coming for it, should have new rods, rings & bearings friday arvo.
Then I'll be back onto the idle issue and tacho. Has anyone got a jimny ecu pin out for g13bb? and / or service manual?
Cheers guys, Simon.
atari4x4
 Posted: Wed Dec 08, 2010 9:24 am |
pics of your variable compression rods...
royce
 Posted: Wed Dec 08, 2010 9:34 am |
g16b does this when the MAF is a bit dirty, are they a similar setup?
superduki
 Posted: Wed Dec 08, 2010 9:56 am |
atari4x4 wrote: pics of your variable compression rods...
you have the pic i took Gus, you upload it, I haven't taken it off my iDingle to my laptop yet!
superduki
 Posted: Wed Dec 08, 2010 9:58 am |
royce wrote: g16b does this when the MAF is a bit dirty, are they a similar setup?
Nope, map unfortunately. One thing I did notice is the idle is alot lower when the alternator is connected, but I've checked my charge rate and sense wire to the alt, and is working fine!
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Wed Dec 08, 2010 10:15 am |
Re-set your base idle, it should have a air bypass screw in the throttle body, just unplug the IAC & adjust the screw till you get the idle you want, then plug it back in..
I run mine disconnected all the time, just run's off base idle, even with P/s..
_________________ I used to be indecisive,
atari4x4
 Posted: Wed Dec 08, 2010 10:18 am |
superduki wrote: atari4x4 wrote: pics of your variable compression rods... you have the pic i took Gus, you upload it, I haven't taken it off my iDingle to my laptop yet!
it's still stuck inside my iFail 4...
superduki
 Posted: Wed Dec 08, 2010 10:19 am |
steak_knife wrote: Re-set your base idle, it should have a air bypass screw in the throttle body, just unplug the IAC & adjust the screw till you get the idle you want, then plug it back in.. I run mine disconnected all the time, just run's off base idle, even with P/s..
Thanks mate, thats exactly what I was after! Once I put it back together (hopefully sunday, but have my work chrissy dinner sat night) I'll try that!
Brenno
 Posted: Wed Dec 08, 2010 2:15 pm |
I have a jimny manual I think however it is 5000km east of me at the moment, I get back from Perth Sunday so during the week one night - or just google one
