| Author |
Message |
Sutho
Joined: Sun Jan 10, 2010 10:30 pm Posts: 735 Location: Scenic Rim, Qld
Vehicle: 1995 SWB Sierra TinTop
 Posted: Sat Dec 25, 2010 8:23 am |
can anyone draw up a wirin diagram i can use for rocklights?
one seperate from everything so i can just turn them on and off whenever i wanna, so i dont have to have the head lights on to run them
i have some time off so im goin to get around to finally do these
_________________ 95 Sierra SJ70 TinTop
Sutho
 Posted: Sat Dec 25, 2010 8:43 am |
i found this on a site after a google search,
is that the easiest??
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Sat Dec 25, 2010 8:45 am |
What bulb's, if they are 55w's you would want a relay or 2..
_________________ I used to be indecisive,
steak_knife
 Posted: Sat Dec 25, 2010 8:46 am |
& a FUSE!!!!
Sutho
 Posted: Sat Dec 25, 2010 8:52 am |
yer stek i googled it and this site came up to wire them into a jeep haha so im goin to go with their set up with a fuse and a relay
you should check it out its pretty cool well the rock light part is haha not the jeep part
http://www.rockcrawler.com/techreports/ ... light5.htm
Sutho
 Posted: Sat Dec 25, 2010 8:55 am |
im using 4 of these from super theif and gettin the relay and fuse there, he i have a 6 meter roll of speaker wire, can i just use that?
89_tintop
Joined: Fri Aug 07, 2009 11:30 pm Posts: 3159 Location: gold coast
 Posted: Sat Dec 25, 2010 8:57 am |
i wouldnt use speaker wire.. and would run 2 relays for 4 lights
royce
 Posted: Sat Dec 25, 2010 8:58 am |
no you cant use speaker wire
you need
From Battery positive a 30 amp fuse, then 6mmish cable to pin 30 and pin 86 on your relay
then run 4mm from each pin 87 to ONE PAIR only of lights, so youll have 2 lots of cable running down, earth the lights on their mounts
stick a normal toggle switch in the dash and run a thin (speaker ok here) from pin 85 to one side of the switch, run the other side of the switch to an earth and your done
steak_knife
 Posted: Sat Dec 25, 2010 9:03 am |
If you use speaker wire we will require pic's..
Don't use speaker wire, it's called SPEAKER wire for a reason..
royce
 Posted: Sat Dec 25, 2010 9:06 am |
actually really its still wire, just finer strand so it flexes better and usually less resilient insulation, protected and big enough it works fine, but to be big enough it would be heaps dearer than normal cable
Sutho
 Posted: Sat Dec 25, 2010 9:13 am |
royce i got this diagram i drew which is a exact replica of the one on the site
HOW DO U RUN 2 RELAYS? ( im not shouting haha )
royce
 Posted: Sat Dec 25, 2010 9:15 am |
for 2 relays join pin 86 together run the rest separate
in my opinion 4 55w lights isnt too much for a 30 amp relay
Sutho
 Posted: Sat Dec 25, 2010 9:17 am |
so u dont recon i should bother running 2 relays?
but is that diagram right?
royce
 Posted: Sat Dec 25, 2010 9:21 am |
Sutho
so thats what u reckon? but ground onto their own mounts
steak_knife
 Posted: Sat Dec 25, 2010 9:22 am |
Sutho wrote: so u dont recon i should bother running 2 relays? but is that diagram right? royce wrote: no you cant use speaker wire
you need
royce
hang on, swap 30 and 87, get a relay with 2 87 pins (not an 87 and 87a)
Sutho
 Posted: Sat Dec 25, 2010 9:23 am |
you need
From Battery positive a 30 amp fuse, then 6mmish cable to pin 30 and pin 86 on your relay then run 4mm from each pin 87 to ONE PAIR only of lights, so youll have 2 lots of cable running down, earth the lights on their mounts
thatts different to my diagram?
Sutho
 Posted: Sat Dec 25, 2010 9:26 am |
so thats the go?
steak_knife
 Posted: Sat Dec 25, 2010 9:28 am |
Sutho wrote: royce wrote: no you cant use speaker wire
you need
stick a normal toggle switch in the dash and run a thin (speaker ok here) from pin 85 to one side of the switch, run the other side of the switch to an earth and your done thatts different to my diagram? Yes.. Sutho wrote:  so thats what u reckon? but ground onto their own mounts
steak_knife
 Posted: Sat Dec 25, 2010 9:29 am |
One pair of light's per relay....
That last one you posted look's right ..
Sutho
 Posted: Sat Dec 25, 2010 9:31 am |
steak_knife wrote: One pair of light's per relay....
ok sweet as thanks stek, now to get the lights and the goods and BAM rocklights
Sutho
 Posted: Sat Dec 25, 2010 9:32 am |
steak_knife
 Posted: Sat Dec 25, 2010 9:33 am |
Sutho wrote: steak_knife wrote: One pair of light's per relay....
That last one you posted look's right .. ok sweet as thanks stek, now to get the lights and 2 friggin relay's & fuses and BAM rocklights
Typo..
royce
 Posted: Sat Dec 25, 2010 9:35 am |
dont need 2 relays for 4 downlights
Sutho
 Posted: Sat Dec 25, 2010 9:41 am |
sorry, i dont understand the 2 relays? i was just gunna do this
fritter
Joined: Sun Sep 19, 2010 9:30 am Posts: 1163 Location: Wahroonga NSW
Vehicle: 89 Vit. The Desert Rat...
 Posted: Sat Dec 25, 2010 10:01 am |
4 x 55w lights = 220 watts. at 12 volts that's going to draw 18.3 amps. So as Royce said one 30 amp relay will be ok. I'd use a 30 amp fuse and the 6mm wire to the relay as a minimum. You might want to start thinking about an alternater upgrade if you're running spotties, headlights, fridge etc as well..
Sutho
 Posted: Sat Dec 25, 2010 10:10 am |
yer mate cool as, yer i have a ford alternator next to my bed ready to go in haha
fordem
 Posted: Sat Dec 25, 2010 11:24 am |
Not really into rocks myself, but, I would have thought that this would be the ideal application for LED lighting - shallow (front to back), bright, diffuse - and low current draw.
atari4x4
 Posted: Sat Dec 25, 2010 11:38 am |
+ i'm planning to replace my 55w rock lites with LED strip lights.
