It is currently Wed Oct 07, 2026 7:47 am
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sat Dec 25, 2010 8:23 am
can anyone draw up a wirin diagram i can use for rocklights?
one seperate from everything so i can just turn them on and off whenever i wanna, so i dont have to have the head lights on to run them
i have some time off so im goin to get around to finally do these
95 Sierra SJ70 TinTop
Post Posted: Sat Dec 25, 2010 8:43 am
i found this on a site after a google search,
is that the easiest??
Post Posted: Sat Dec 25, 2010 8:45 am
What bulb's, if they are 55w's you would want a relay or 2..
Post Posted: Sat Dec 25, 2010 8:46 am
& a FUSE!!!!
Post Posted: Sat Dec 25, 2010 8:52 am
yer stek i googled it and this site came up to wire them into a jeep haha so im goin to go with their set up with a fuse and a relay
you should check it out its pretty cool well the rock light part is haha not the jeep part
http://www.rockcrawler.com/techreports/ ... light5.htm
Post Posted: Sat Dec 25, 2010 8:55 am
im using 4 of these from super theif and gettin the relay and fuse there, he i have a 6 meter roll of speaker wire, can i just use that?
Post Posted: Sat Dec 25, 2010 8:57 am
i wouldnt use speaker wire.. and would run 2 relays for 4 lights
Post Posted: Sat Dec 25, 2010 8:58 am
no you cant use speaker wire
you need
From Battery positive a 30 amp fuse, then 6mmish cable to pin 30 and pin 86 on your relay
then run 4mm from each pin 87 to ONE PAIR only of lights, so youll have 2 lots of cable running down, earth the lights on their mounts
stick a normal toggle switch in the dash and run a thin (speaker ok here) from pin 85 to one side of the switch, run the other side of the switch to an earth and your done
Post Posted: Sat Dec 25, 2010 9:03 am
If you use speaker wire we will require pic's.. :lol:
Don't use speaker wire, it's called SPEAKER wire for a reason..
Post Posted: Sat Dec 25, 2010 9:06 am
actually really its still wire, just finer strand so it flexes better and usually less resilient insulation, protected and big enough it works fine, but to be big enough it would be heaps dearer than normal cable
Post Posted: Sat Dec 25, 2010 9:13 am
royce i got this diagram i drew which is a exact replica of the one on the site
HOW DO U RUN 2 RELAYS? ( im not shouting haha )
Post Posted: Sat Dec 25, 2010 9:15 am
for 2 relays join pin 86 together run the rest separate
in my opinion 4 55w lights isnt too much for a 30 amp relay
Post Posted: Sat Dec 25, 2010 9:17 am
so u dont recon i should bother running 2 relays?
but is that diagram right?
Post Posted: Sat Dec 25, 2010 9:21 am
diagram is right
so thats what u reckon? but ground onto their own mounts
Post Posted: Sat Dec 25, 2010 9:22 am
you need
hang on, swap 30 and 87, get a relay with 2 87 pins (not an 87 and 87a)
Post Posted: Sat Dec 25, 2010 9:23 am
you need
thatts different to my diagram?
Post Posted: Sat Dec 25, 2010 9:26 am
so thats the go?
Post Posted: Sat Dec 25, 2010 9:28 am
you need
Yes..
Post Posted: Sat Dec 25, 2010 9:29 am
One pair of light's per relay....
That last one you posted look's right ..
Post Posted: Sat Dec 25, 2010 9:31 am
ok sweet as thanks stek, now to get the lights and the goods and BAM rocklights 8) 8) 8) :twisted:
Post Posted: Sat Dec 25, 2010 9:32 am
http://www.rockcrawler.com/techreports/ ... light2.htm
AWESOME HELP SITE FOR ROCKLIGHT SETUP AND STEP BY STEP TALK THROUGH (for a jeep)
Post Posted: Sat Dec 25, 2010 9:33 am
ok sweet as thanks stek, now to get the lights and 2 friggin relay's & fuses and BAM rocklights 8) 8) 8) :twisted:
Typo.. :lol:
Post Posted: Sat Dec 25, 2010 9:35 am
dont need 2 relays for 4 downlights :)
Post Posted: Sat Dec 25, 2010 9:41 am
sorry, i dont understand the 2 relays? i was just gunna do this
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Sat Dec 25, 2010 10:01 am
4 x 55w lights = 220 watts. at 12 volts that's going to draw 18.3 amps. So as Royce said one 30 amp relay will be ok. I'd use a 30 amp fuse and the 6mm wire to the relay as a minimum. You might want to start thinking about an alternater upgrade if you're running spotties, headlights, fridge etc as well..
Post Posted: Sat Dec 25, 2010 10:10 am
yer mate cool as, yer i have a ford alternator next to my bed ready to go in haha
Post Posted: Sat Dec 25, 2010 11:24 am
Not really into rocks myself, but, I would have thought that this would be the ideal application for LED lighting - shallow (front to back), bright, diffuse - and low current draw.
Post Posted: Sat Dec 25, 2010 11:38 am
+ i'm planning to replace my 55w rock lites with LED strip lights.
Users browsing this forum: No registered users and 155 guests
