It is currently Thu Oct 22, 2026 3:03 pm
Post Posted: Wed Feb 16, 2011 10:56 am
Even though the FSM mentions only using DOT3 is it OK to use DOT4 instead?
Wouldn't DOT 4 being a more advanced fluid be better then using the older DOT 3 as it has higher boiling properties but still based off the same glycol mix?
2002 SWB GV
Lifted and Locked
Post Posted: Wed Feb 16, 2011 11:01 am
4 dot's please, dot 3 is almost non existent, even Suzuki think it's strange that they still specifie 3 dot's....
Post Posted: Wed Feb 16, 2011 11:16 am
Dot 3, 4, 5.1 are interchangeable and will mix.
Dot 5 is not interchangeable. Will not mix. Whole system has to be flushed clean and dry for dot 5. A limited amount of brakes use dot 5.
A good explanation For dot 3 and linked to others: http://en.wikipedia.org/wiki/DOT_3
Post Posted: Wed Feb 16, 2011 6:19 pm
dot 3 is still quite common alot of toyotas and subarus specify only dot3
Post Posted: Wed Feb 16, 2011 9:51 pm
So what gives then???
The brake fluid reservoir cap on my GV says DOT3 ONLY, the FSM only states DOT3.
Could there be parts compatibility issues?
2002 SWB GV
Lifted and Locked
Users browsing this forum: No registered users and 131 guests
