Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
Posted: Wed Feb 16, 2011 10:56 am
Even though the FSM mentions only using DOT3 is it OK to use DOT4 instead?
Wouldn't DOT 4 being a more advanced fluid be better then using the older DOT 3 as it has higher boiling properties but still based off the same glycol mix?
Users browsing this forum: Google [Bot] and 226 guests
