Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Zooknoob
Joined: Sat Jan 08, 2011 11:02 pm Posts: 94 Location: Perth, WA
 Posted: Sun Mar 20, 2011 1:57 am |
id say someone on here has fitted soft top rear seat i got a set of the two indervidual 1s but the two hook brackets dont line up to the holes already in the chassy any ideas ?
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Sun Mar 20, 2011 1:59 am |
Swap the seats from side to side maybe
_________________ Shep is a closet jimny lover!!!!
Zooknoob
 Posted: Sun Mar 20, 2011 3:15 am |
do you have to take your tank off to put the seats back on?
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Sun Mar 20, 2011 3:24 am |
Turn the bracket around??
Tank (fuel) should be fine where it is, unless you have stripped the bolt, in which case it should be fine where it is..
_________________ I used to be indecisive,
Zooknoob
 Posted: Sun Mar 20, 2011 3:38 am |
yer thats what ive gotta do but bolts spinning underneith sthink i gotta take fuel tank off flip it and put tank back bit more effot then i thort
steak_knife
 Posted: Sun Mar 20, 2011 3:47 am |
For the seat or the bracket??
You can undo the tank bolt's & not take em all the way out, will give you just enough room to get a arm in there, if it's not, put a trolley jack under it & use that to lower the tank down a lil bit..
It the weld's have snapped on the captive nut, you'll need to use nut, bolt & washer, so don't fit the tank up till it's bolted down again..
is that better Scrawny??
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 217 guests
