It is currently Mon Sep 21, 2026 2:59 am
Post Posted: Sun Mar 20, 2011 1:57 am
id say someone on here has fitted soft top rear seat i got a set of the two indervidual 1s but the two hook brackets dont line up to the holes already in the chassy any ideas ?
Post Posted: Sun Mar 20, 2011 1:59 am
Swap the seats from side to side maybe
Post Posted: Sun Mar 20, 2011 3:15 am
do you have to take your tank off to put the seats back on?
Post Posted: Sun Mar 20, 2011 3:24 am
Turn the bracket around??
Tank (fuel) should be fine where it is, unless you have stripped the bolt, in which case it should be fine where it is.. :D
Post Posted: Sun Mar 20, 2011 3:38 am
yer thats what ive gotta do but bolts spinning underneith sthink i gotta take fuel tank off flip it and put tank back bit more effot then i thort
Post Posted: Sun Mar 20, 2011 3:47 am
For the seat or the bracket??
You can undo the tank bolt's & not take em all the way out, will give you just enough room to get a arm in there, if it's not, put a trolley jack under it & use that to lower the tank down a lil bit..
It the weld's have snapped on the captive nut, you'll need to use nut, bolt & washer, so don't fit the tank up till it's bolted down again..
is that better Scrawny??
Users browsing this forum: Google [Bot] and 201 guests
