It is currently Sat Sep 19, 2026 11:03 pm
Post Posted: Mon Mar 28, 2011 4:01 am
Hello fellow Medicated Auszookers
As you all might have read in other posts of mine, that i am keen to build my own front bar... well this is slowly getting rolled into action and the cogs have stopped grinding in my head and started turning...
I have a Few Questions.
1. How do i make my own Winch Cradle, does every winch have a different cradle??? Has someone got the dimensions for a Winch cradle???
2. How many points through the chassis should i be bolting it. I Believe (and correct me if im wrong) To bolt things through the chassis you have to drill the hole bigger then weld a piece of tube Through the hole??? "Crush tube"
:cheers:
Stocker
Vehicle: LWB Sierra & XL7
Post Posted: Mon Mar 28, 2011 4:16 am
:lol:
Seriously that is exactly what I am looking on ebay at this very second.
This is the one I was about to get: http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0472736522
I was going to cut it down to size and weld it to the bar. But I thought I'd jump on here and ask Fatzook to see if he can make one up.
'92 Vitara & Camper trailer
Post Posted: Mon Mar 28, 2011 4:33 am
i see says the blind man as he was handed a hammer and saw :-)
So that bolts to the bottom of the winch?
if he's keen to make two even better ;)
Stocker
Post Posted: Mon Mar 28, 2011 4:37 am
Buxbox the one you have linked to looks like a multifit sort of thing. They can sometimes be more work than they are worth.
And that one looks pretty light duty. :?
Get me some dimensions of what you want and I'll knock one up from 8mm steel. :wink:
Post Posted: Mon Mar 28, 2011 4:38 am
ok this brings me to another question, would it be easier for me to get a winch first up then build the bar around the winch???
Stocker
Post Posted: Mon Mar 28, 2011 4:52 am
i just got the recommended specs from the winch manufacturer and added a bit
extra for good luck. :lol:
from memory it was 6mm plate and i used 10mm.
mine is mounted feet down so i dunno if all winch's can be mounted like that.
For most people I would say yes. Its easier to work around the onstacles if they are right infront of you. :wink:
Vehicle: Zookless
Post Posted: Mon Mar 28, 2011 4:59 am
That's exactly what I did :D
Pics here.
Post Posted: Mon Mar 28, 2011 7:43 am
So im just curious about the mounting to the chassis bit. do you have to weld in tubes if you drill through the chassis
Stocker
Vehicle: Zookless
Post Posted: Mon Mar 28, 2011 7:49 am
Mine is bolted to the end of the chassis rails. There's already holes there, I just added some small crush tubes to fit.
Post Posted: Mon Mar 28, 2011 7:53 am
Post Posted: Mon Mar 28, 2011 8:10 am
[quote="buzbox"][/quote]
Your Blue Bits are showing :wink:
Stocker
Users browsing this forum: No registered users and 189 guests
