Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
mudzookacoatsy
Joined: Fri Jul 31, 2009 11:30 pm Posts: 380 Location: ipswich
 Posted: Wed May 04, 2011 11:05 am |
hey all i tryed to find old post bout bodylifts but cant. just wanting to know that easiest way of doing them and are they worth it. i got 2'' spring lift with standed shackles did have ext ones. just after a lil bit more height .
_________________ 2''lift 31's twin locked & 6.5s
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Wed May 04, 2011 11:06 am |
Are you trying to fit larger tyres? Or is it just lift for the sake of lift?
_________________ 2013 GV 1998 SV420 ute
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed May 04, 2011 11:07 am |
Picture looks like 31's.
I assume tyre clearance and looks.
_________________ mlm
xedent
Joined: Mon Jun 15, 2009 11:30 pm Posts: 895 Location: Sunshine Coast, QLD
 Posted: Wed May 04, 2011 7:44 pm |
So does his signature.
_________________ My Maruti build, Click WWW
nato78
Joined: Fri Apr 09, 2010 11:30 pm Posts: 1504 Location: Auckland, NZ
Vehicle: Yamaha scooter, 50cc
 Posted: Wed May 04, 2011 10:19 pm |
Start spraying your bolts with wd40 or similar a few days before you plan on puting your lift in, will make it heaps easier to undo them when you start.
Remove front and rear bars, grill and disconnect fuel filler hose at the neck before you start. Then remove ALL 10 body retention bolts.
Then just use a trolley jack to start lifting the body off the chasis and insert blocks, do one side at a time. Make sure all 10 blocks are in before you put any bolts back in.
Make sure when you start jacking that you aren't overstretching any hoses or cables and loosen as necessary
That's all I got, someone else may be a bit more helpful
nato78
 Posted: Wed May 04, 2011 10:27 pm |
SierraDan
 Posted: Wed May 04, 2011 10:42 pm |
xedent wrote: So does his signature.
Haha, Geez.. How did I manage to notice the tyre size in the picture but not the sig..
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 463 guests
