It is currently Thu Oct 29, 2026 11:29 pm
Post Posted: Wed May 04, 2011 11:05 am
hey all i tryed to find old post bout bodylifts but cant. just wanting to know that easiest way of doing them and are they worth it. i got 2'' spring lift with standed shackles did have ext ones. just after a lil bit more height .
2''lift 31's twin locked & 6.5s
Post Posted: Wed May 04, 2011 11:06 am
Are you trying to fit larger tyres? Or is it just lift for the sake of lift?
Post Posted: Wed May 04, 2011 11:07 am
Picture looks like 31's.
I assume tyre clearance and looks.
Post Posted: Wed May 04, 2011 7:44 pm
So does his signature. :)
My Maruti build, Click WWW
Vehicle: Yamaha scooter, 50cc
Post Posted: Wed May 04, 2011 10:19 pm
Start spraying your bolts with wd40 or similar a few days before you plan on puting your lift in, will make it heaps easier to undo them when you start.
Remove front and rear bars, grill and disconnect fuel filler hose at the neck before you start. Then remove ALL 10 body retention bolts.
Then just use a trolley jack to start lifting the body off the chasis and insert blocks, do one side at a time. Make sure all 10 blocks are in before you put any bolts back in.
Make sure when you start jacking that you aren't overstretching any hoses or cables and loosen as necessary
That's all I got, someone else may be a bit more helpful
Post Posted: Wed May 04, 2011 10:27 pm
You may find this helpful, it's on outers
http://www.outerlimits4x4.com/viewtopic.php?t=93393
I didn't have to touch the steering column when I did mine, so just work it out as you go
Post Posted: Wed May 04, 2011 10:42 pm
Haha, Geez.. How did I manage to notice the tyre size in the picture but not the sig..
Users browsing this forum: Google [Bot] and 120 guests
