Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
Posted: Tue May 24, 2011 3:24 am
Don't need it for a 40mm lift, but, with it the steering will feel very solid and cornering will be improved too. Overall the Jim will drive much better.
Joined: Thu Aug 26, 2010 8:21 am Posts: 434 Location: Toowoomba
Posted: Tue May 24, 2011 5:24 am
When I got the OME 40mm kit, I thought I was going to die - the steering wobble was that bad. (about when I hit 70kmph). I had never experienced anything like it.
I then got a 3degree castor correction and then the Jimny felt perfect...at any speed.
So I'd say, only get the castor correction if you need it judging by other comments.
_________________ Better than stock...but not by much.
Joined: Fri Sep 03, 2010 11:36 am Posts: 106 Location: Central Victoria
Posted: Tue May 24, 2011 6:59 am
When I got my 40mm lift done I was told the same and it was only after getting an alignment check that it was noticed that the castor was out and I had fitted adjustable castors to bring it back to specs and now there is a big difference in the way it handles.
Paul
Users browsing this forum: Google [Bot] and 263 guests
